05 supercharged - Mustang Evolution
Old 11-16-2012, 09:27 AM   #1
Crshelton21's Avatar
05 supercharged
Hey I am new to the mustang world as of last night! I've always loved the 05-09 body style and finally got one. This one just so happened to have a vortec supercharger. (I'm excited).
Anyways. It also has a fuel mixture setting in the trunk to where you mix it lean on one side or rich on the other. My question is this. What do I need to do reg regularly to maintain the charger. Anyone know about the fuel ratio?any other tips are welcome.
Crshelton21 is offline   Reply With Quote
Old 11-16-2012, 09:34 AM   #2
Also. I am clueless when it comes to superchargers. Know a lot about mustangs but nothing about this stuff. Have a box full of receipts as well.
There is a diablo control module looking thing on top the motor it's got wired running through it on either side. It lights up for a second when I turn the car on. What the heck does that thing do?
Old 11-16-2012, 09:38 PM   #3
Sirtat's Avatar
hello and congrats on the slick ride... do you have a V2 or V3 ?
I don't know about the lean/rich dial in the truck maybe post a pic and leave it alone,for now...
the diablo sport under your hood is probably a mafia required when your mass air flow voltage would max out so it has 5 settings to recalibrate the voltage you computer receives..
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 11-17-2012, 08:10 AM   #4
It is a v2. Anything special I need to Know or do with them? It also has a k&n filter on it. On a deisel those are bad for the turbos. Is a k&n bad for the vortec?
Old 11-17-2012, 08:14 AM   #5
This is the fuel mixer in the trunk.
Old 11-17-2012, 08:33 AM   #6
Bennyhill's Avatar
It's a 2v 05? Are you sure?
Bennyhill is offline   Reply With Quote
Old 11-17-2012, 08:49 AM   #7
tc x 4's Avatar
V2
Old 11-17-2012, 10:51 AM   #8
Attachment 76334
That is the KB BAP control box. It increases voltage to the fuel pump so that you will have more fuel when going into boost to prevent a lean condition. The increments on the controller is set to the % voltage increase required to supply sufficient fuel for the boost level of your particular S/C. It is otherwise a passive system and only activates when commanded. Most tuners recommend setting the dial to 50 and leave it alone.
2006 GT Redfire 5 Spd Manual. Saleen S/C. Custom Diablo tune by Adam @ ST Motorsports, San Bernardino, CA.
Redfire281 is offline   Reply With Quote
Old 11-17-2012, 04:38 PM   #9
Ok awesome! Thanks ! That helps a lot. It was on the setting it is now when I got it. It also has I believe an sct tuner. I haven't messed with it either cause I don't want to mess anything up lol
Old 11-17-2012, 04:40 PM   #10
Sirtat's Avatar
the 05 is a 3 valve. I was asking what supercharger he has a vortec V-2 (is lubricated by engine oil) or a vortec V-3 (self contained oil)
as far as a k&n, that is what I was running on mine.
IBLT IT
Old 11-17-2012, 04:42 PM   #11
It's a vortec v2.
Old 11-17-2012, 04:45 PM   #12
Sirtat's Avatar
I would recommend not adjusting where it was when you received it, our fuel pumps are a demand system with no return line so the computer will send say 5volts at idle and maxes out at 12v if needed to supply adequate fuel pressure, the boosta pump will take that 12v and boost it up to 17v if needed to maintain pressure
I have a competition boosta pump that will take voltage up to 21v but I have no dial on mine to adjust,was all done by my tuner in the fuel tables
IBLT IT
Old 11-17-2012, 04:52 PM   #13
So leave it where it is?
Old 11-17-2012, 04:59 PM   #14
Sirtat's Avatar
I would until You call KB on Monday, they answer right away.. And will give you the definite answer.. I would also find out who tuned the car, I was able to find out sooo much info on my car from the tuner, mind you all the set-up is soo in the past.
but the tuner would probably have adjusted the boosta pump to the min setting req to maintain pressure and those fuel tables could be all wrong of you adjust the dial from where he did all his tuning, if nothing else call KB and get ahold of the tuner.. IMO
IBLT IT
Old 11-20-2012, 01:51 PM   #15
How long should it be before I have the clutch replaced? Shifting into 1st in this thing is not a quick process. It SUCKS!
Old 11-27-2012, 07:13 PM   #16
Sirtat's Avatar
I have a center force duel friction, poor thing is way beyond its rated HP/trq.. it is tried and true til 500hp IMO.. I down shift EVERYTIME I come to a light lol with. o problems... if it is in the budget replace it as soon as convenient, you will love it.. and by the way BUY A WOT BOX... I luv mine, 2 stage in second gear and dump the clutch coolest thing ever
IBLT IT
Old 11-27-2012, 07:49 PM   #17
Does yours grab high?
muscledom is offline   Reply With Quote
Old 11-27-2012, 08:00 PM   #18
Sirtat's Avatar
mid way
---------- Post added at 09:00 PM ---------- Previous post was at 09:00 PM ----------
how old is your clutch ? stock ?
IBLT IT
Old 11-27-2012, 08:21 PM   #19
mid way
Yea I guess mines just past midway. Doesn't grab hard till the top though. It's a centerforce dual friction. About a month or so old.
Old 11-27-2012, 08:25 PM   #20
Sirtat's Avatar
and hard to downshift ? or always. ? reverse hard too ?
IBLT IT
Old 11-27-2012, 08:32 PM   #21
Nah man shifts perfect. Just grabs high. Doesn't slip or anything.
Old 11-27-2012, 08:39 PM   #22
BaSohol's Avatar
Ya my CenterForce grabs ever so slightly mid way then grabs hard, idk shifts fine has for about 11,000 miles like that
---------- Post added at 10:39 PM ---------- Previous post was at 10:38 PM ----------
Also if I needed a new clutch tomorrow I'd buy another CenterForce, best clutch IMHO
2007 Ford Mustang GT 5spd
Old 11-28-2012, 12:43 AM   #23
Sirtat's Avatar
center force is a great medium duty clutch IMO... at this point I couldn't not use a center force as I have surpassed there ratings, there for I will buy a spec or McLeod they are a higher rated clutch..so I you plan on building a monster you may have to go beyond the center force
IBLT IT
Old 11-28-2012, 05:33 AM   #24
Ok im gonna need some links. Lol I have no idea what all that is. New to this remember? Haha
Old 03-03-2013, 04:12 PM   #25
Would anyone be interested in buying this stang? 84,500 miles. Rated for 450hp. Asking 14,200
Old 03-03-2013, 04:14 PM   #26
Kcstunna82's Avatar
Why you selling didnt you just get it?
Kcstunna82 is offline   Reply With Quote
Old 03-03-2013, 05:02 PM   #27
Luna1994's Avatar
Region: Utah
Ill take that supercharger off ur hands
Luna1994 is offline   Reply With Quote
Old 03-03-2013, 05:46 PM   #28
Coltonhess's Avatar
The threads a year old.
Coltonhess is offline   Reply With Quote
Old 03-03-2013, 06:03 PM   #29
Kcstunna82's Avatar
4 months ago but ok
Old 03-03-2013, 06:15 PM   #30
Coltonhess's Avatar
4 months ago but ok
Oops my bad. I thought that said 1-12 instead of 11-12.
Old 03-03-2013, 06:23 PM   #31
DaBluedude's Avatar
Where are you located?
2003 Mach 1
Old 03-03-2013, 06:25 PM   #32
tc x 4's Avatar
That's a good starting price, but I wouldn't count on it.
Old 03-04-2013, 05:07 AM   #33
I decided to buy a truck instead so in trying to pay down on some debt.
Old 03-04-2013, 06:34 AM   #34
MikesChargedGT's Avatar
I want the supercharger! Really? That seems like a low price I bought my 08 for 22k (kbb) 28k with 18k miles
"Too much horsepower is not enough"
MikesChargedGT is offline   Reply With Quote
Old 03-05-2013, 05:15 AM   #35
Gallatin, tn
11:44 PM
