E Brake troubles please help!! - Mustang Evolution
Old 11-19-2012, 12:36 PM   #1
Crshelton21's Avatar
So bought this mustang last week. Found out the e brake doesn't work. I've searched the Internet looking for answers. Adjusted the nut on the cable and it still doesn't seem to be working. Going to post a picture of it, does all this look normal???
Crshelton21 is offline   Reply With Quote
Old 11-19-2012, 01:22 PM   #2
It's not me, it's you.
primer2tone's Avatar
The problem is probably on the wheel. It might be time for a rear brake job.
Old 11-19-2012, 01:44 PM   #3
IanM's Avatar
+1
How many miles on the car? Might be time to change the rear brakes anyway, i'd probably go ahead and do it while i'm in there if they're worn, so it's good to go for a long time. Usually one thing leads to another, if your parking brake isn't working, i'd bet there might be more that needs done at the wheel as far as adjustment and replacement of some wear parts.
IanM is offline   Reply With Quote
Old 11-19-2012, 01:47 PM   #4
It has just over 80k
Old 11-19-2012, 01:53 PM   #5
IanM's Avatar
I'd have the rear brakes checked then, lots of places will do it for free when you get other services performed. At 80k, they might have never been done, and may be due. I'll bet you just need the parking brake adjusted while they're in there (if you had a shop do it that is).
Old 11-19-2012, 02:15 PM   #6
I have one but. Would really prefer to do it myself to save money. How time consuming would that be? Never done it before.
Old 11-19-2012, 02:41 PM   #7
IanM's Avatar
Here's a video of a guy doing the change on an 06 GT rear pads. You'll need a brake tool to rotate and compress the piston, but otherwise it's pretty straight forward.
The first time you do it, it'll take a bit longer just because its unfamiliar, but once you do it a few times, maybe 30-60 minutes per side. Depending on if you need rotors as well, might take a bit longer. Get a friend to help you, and plan for an afternoon of getting your hands dirty.
Old 11-19-2012, 06:57 PM   #8
Alonzo.dargan1's Avatar
Your ebrake cable is snapped. Same thing happened to me. Only way to fix it is by buying the ebrake lever, which costs $165 from ford.
Alonzo.dargan1 is offline   Reply With Quote
Old 11-20-2012, 05:06 AM   #9
Is it just the lever you pull up I'd have to buy?? Or the cable as well??
Old 11-20-2012, 09:53 AM   #10
tc x 4's Avatar
Just the cable.
Old 11-20-2012, 09:57 AM   #11
Adogg's Avatar
Check ur rear calipers the e brake spring on the caliper could be junk and in that case you will have to replace the rear calipers and the cable cause it is going to be bad to
Don't hate....... appreciate
Old 11-20-2012, 10:12 AM   #12
Send a message via AIM to Borii
WITHOUT experience is should take 30 per side. WITH experience it is literally minutes. Without the rotating tool you end up needing a confession lol
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 11-20-2012, 11:31 AM   #13
IanM's Avatar
No kidding on the confession... First time I ran into that I broke a c-clamp before i realized i needed a special tool for turning and compressing the piston. What a mother that was...glad i broke the cheap clamp instead of the caliper though...
You're right about the time, it shouldn't take but a few minutes, I just enjoy my time in the garage so i work slowly.
12V Relay Brake Bypass? ColeJohnson Mustang Audio & Video 8 01-26-2012 10:22 AM
Weird brake thing that happened RVAStang05 2005-2010 Mustang GT 0 11-12-2011 07:51 AM
Lowering the 2012 5.0 Brembo Brake Package avengnd 2011-2014 Mustang GT 33 10-28-2011 08:47 PM
Brake upgrade!!! gvstack 1979-1995 Mustang GT 1 10-27-2011 03:16 PM
Most Popular Brake Pads Brent 1996-2004 Mustang GT 18 09-18-2011 11:29 AM
02:20 AM
