Front end clunks??? - Mustang Evolution
Old 11-20-2012, 03:18 PM   #1
Front end clunks???
So yea it's NOT the sway bar links lol. O well. Any ideas? Thinking its the strut mounts. Probably gonna do the mounts and the struts. How's that sound? Thanks fellas
muscledom is offline   Reply With Quote
Old 11-20-2012, 04:32 PM   #2
S197stanGT's Avatar
Region: Idaho
I was recently experiencing a front end clunk also and I replaced my end links, no luck. Thought it were the strut mounts but nope. So I decided to take my sway bar off and drive it and clunk was gone. I replaced my front sway bar mount bushings. Easy, cheap fix. Mines an 07 gt with 75k
S197stanGT is offline   Reply With Quote
Old 11-20-2012, 04:43 PM   #3
Hmmmmmm it seems like its coming just out of the right. Ill take the sway bar off and see what happens. I was gonna do that originally but got impatient which cost me $70 lol. Thanks for the info
Old 11-23-2012, 06:02 AM   #4
tc x 4's Avatar
I've been watching this thread, my jacked up truck has been making the same noise. Your answer makes the most sense to me, I never had the issue til I put 37" tires on it.
---------- Post added at 08:02 AM ---------- Previous post was at 08:00 AM ----------
It makes a really loud poping noise, but drives perfect.
Old 11-23-2012, 06:20 AM   #5
My only problem with that theory for my car is that I can definitely isolate the noise the the front right. Pretty sure it's a strut or the mount. Ill find out this week.
Old 11-25-2012, 01:05 AM   #6
S197stanGT's Avatar
Region: Idaho
If you're doing your own work I would first check the end links or strut mount bushings. It's easy and quick. Just take your sway bar off. Then of its not that proceed with the strut mounts I guess.. How many miles does it have?
Old 11-25-2012, 05:33 AM   #7
81k. Already did the end links. On to the strut mounts.
Old 11-29-2012, 09:13 PM   #8
Check the bolts where the k member mounts to the frame. All mine were loose and the car only has 15,000 miles. Fixed my problem. Good luck!
jjw460 is offline   Reply With Quote
10:20 PM
