Oil all gone?! - Mustang Evolution
Old 11-21-2012, 06:10 AM   #1
Crshelton21's Avatar
Oil all gone?!
So I notice while replacing my fuel filter yesterday that the underside of my car is really wet. Then I looked around the valve cover and the picture is what i saw......is this just a valve cover gasket? I checked it before I rolled out this morning and there was nothing on the stick! Took nearly 2 quarts! The funny thing is is that there is not major puddles on the ground. Just a drop here and there. What's going on??
Crshelton21 is offline   Reply With Quote
Old 11-21-2012, 07:11 AM   #2
Send a message via AIM to Destination S19
Have you ever removed the cam covers before?
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 11-21-2012, 07:58 AM   #3
I just got the car last week. A bunch of work has been done to so I don't know if they have been or not.
Old 11-21-2012, 08:19 AM   #4
BaSohol's Avatar
Probably burned alot of that not leaked
2007 Ford Mustang GT 5spd
Old 11-21-2012, 08:33 AM   #5
Year and milage? Clean everything up and take it from there. Probably a combination of gaskets and blow by. VC gaskets for sure by the looks of it. I have a minor drip here and there, no big deal my car has 81k on it. If you wind out the gears and play a lot you lose oil to blow by. I probably use like 1/4 qt per month.
muscledom is offline   Reply With Quote
Old 11-21-2012, 08:54 AM   #6
05 model and has 80k
Old 11-21-2012, 08:54 AM   #7
Yea just clean it up and take it from there
Old 11-21-2012, 09:20 AM   #8
The part about the underside of the car being really wet is bothersome to me. Keep an eye on that and see if you can trace the source of the leak just in case it's something other than the VC. Also, you mention that you've owned the car for a week so I think it's odd that the seller didn't top off all the fluids to improve the selling value. Just sayin'.
2006 GT Redfire 5 Spd Manual. Saleen S/C. Custom Diablo tune by Adam @ ST Motorsports, San Bernardino, CA.
Redfire281 is offline   Reply With Quote
Old 11-21-2012, 01:32 PM   #9
SCCofSV's Avatar
This may sound stupid but it is something I do, whenever I buy anything used.
I clean the h*** out if it. Inside, outside, top and bottom or underneath. When it comes to vehicles purchases. Even if it's all clean and pretty. I change the oil, the transmission oil and in my case the gear oil to the brand I prefer. This applies even if they said it was recently done, I want to to see the receipts. If it wasn't performed at a Ford dealership. I do it emmediately. Especially, since you really don't know how well the previous owner maintained it. Unless he/she kept all maintenance records. But I digress! Buy a degreaser and or steam clean your engine as well as under the car then dry it off well! Inspect everything and as I said before, don't take anything for granted or assume that they did it.
This way you can see for yourself if there are any new leaks! It just takes all the guess work out of, Is this old stuff or is it new. I'm talking about all oils, fuilds and such. You'll know because you cleaned it previously.
That said, enjoy your new Mustang!
SCCofSV is offline   Reply With Quote
Old 11-21-2012, 01:48 PM   #10
Originally Posted by SCCofSV View Post
..... This way you can see for yourself if there are any new leaks! It just takes all the guess work out of, Is this old stuff or is it new. I'm talking about all oils, fuilds and such. You'll know because you cleaned it previously.
Great advice. Even on general lube and maintenance, I clean any areas I've worked on just to make sure that leaks or oddities I find the next time was caused since I last did the maintenance.
Old 11-21-2012, 04:06 PM   #11
SCCofSV's Avatar
Thank you! I totally agree with what you say. As a kid, I would sit and watch my grandfather work on his Cuda, and EVERY time he was getting his tools out he would say the same thing and then repeat them as he was putting his tools away. I've taught both my daughters the same. Sound Advice.
Old 11-22-2012, 05:59 PM   #12
Stang23's Avatar
Yep that's definitely the smart way to go about your routine maintenance
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
11:55 AM
