New Clutch on 08gt - Mustang Evolution
Old 11-22-2012, 12:41 PM   #1
08SteedaQ350's Avatar
New Clutch on 08gt
I have an 08 GT Steeda Q350
Has 40,000 miles on it.
Looking to buy a full clutch assembly. As I have only had it for a month, I don't have the precious maintenance records. Only clean carfax.
So I'm looking to do some preventative maintenance.
08SteedaQ350 is offline   Reply With Quote
Old 11-22-2012, 12:44 PM   #2
Am I going in the right direction as far as the right clutch with 350 whp? Or bump it up to the Exedy Mach 500 stage 3?
I do plan on adding a few more horses and don't wanna have to buy another clutch to accommodate the increase.
ID:	77222   Click image for larger version
Old 11-22-2012, 02:17 PM   #3
Centerforce dual friction with a stock flywheel.
muscledom is offline   Reply With Quote
Old 11-22-2012, 02:20 PM   #4
It's not me, it's you.
primer2tone's Avatar
Is your mustang a DD? Some of the performance clutches effect the drivability or a rather still clutch pedal.
Old 11-22-2012, 02:22 PM   #5
Yes it's my daily driver.
Just don't wanna put something in that's gonna push the limits of it. And I want a lil room for upgrades too.
Old 11-22-2012, 02:23 PM   #6
How much power do you plan to gain with upgrades? I guess that would be a sure way to match the right clutch with your needs.
Old 11-22-2012, 02:36 PM   #7
I'm just wanting to get to about 400whp.
As per Steeda specs, my car has 368'lb torque and 350hp. 12.7 1/4 mile. I haven't tracked it and I won't be tracking it
And once I drop the money to go FI, then I'll splurge to get the performance clutch to handle that extra power.
---------- Post added at 03:30 PM ---------- Previous post was at 03:28 PM ----------
I have also read that when replacing the clutch, its a good idea to use Ford Racing throw out bearing. Instead of the one provided. Can't find it anywhere tho
---------- Post added at 03:31 PM ---------- Previous post was at 03:30 PM ----------
I'll have to look into that.
---------- Post added at 03:36 PM ---------- Previous post was at 03:31 PM ----------
If you haven't noticed, I'm a confused and very indecisive person lol.
Old 11-22-2012, 02:44 PM   #8
And I assume I have a 10 spline?
Old 11-22-2012, 03:56 PM   #9
That combo was recommended to me by Jake Lamotta. Look him up, he's no joke. He's dynotuning my car next Friday. It's very drivable and not much firmer than stock.
---------- Post added at 06:56 PM ---------- Previous post was at 06:56 PM ----------
And I'm pretty sure that's 350hp on the motor, not to the wheels.
Old 11-22-2012, 04:02 PM   #10
And honestly I wouldn't bother doing a clutch right now unless its slipping or failing otherwise. Just a waste of money at this point in time. Do other mods first.
Old 11-22-2012, 04:16 PM   #11
Thanks. I'm just getting parts that I'll need. I have the $ so it's no biggie. Just getting parts so that when it does need them, I don't have to wait, I'll already have them on hand
Old 11-22-2012, 04:38 PM   #12
tc x 4's Avatar
+1
Old 11-22-2012, 04:51 PM   #13
So what kind of build are you planning on?
Old 11-22-2012, 05:03 PM   #14
Well I can't build much of a sleeper cause it already looks like a beast.
I'm just looking to get up around 400hp.
Once I get back to work, then I will drop the money to go FI.
Old 11-22-2012, 05:11 PM   #15
Yea FI is the cheapest way to get 400rwhp. NA is a ***** lol
Old 11-22-2012, 05:13 PM   #16
What's the price tag on FI run?
Supporting mods?
Old 11-22-2012, 05:38 PM   #17
Stang23's Avatar
Supporting mods?
Forced induction can be big bucks depending on what you plan on doing with the car. Are you gunna build the motor or just slap a supercharger on it? And what kind of supercharger do you want to go with?
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 11-22-2012, 05:42 PM   #18
See that's the thing. I want longevity out of my motor. I'd in no way just slap a charger on it.
I'd like to go with a whipple
But not sure if the stock block can handle it for as long as I wanna keep the car. So I'd probably need to build a motor huh?
---------- Post added at 06:42 PM ---------- Previous post was at 06:41 PM ----------
When I get to the point that I wanna do FI, I plan on dropping around 10k. But that's later down the road if I don't pick up another Stang that's already charged
Old 11-22-2012, 05:51 PM   #19
Stang23's Avatar
Building the motor is the best thing to do even if your only at 400 or 450 to the wheels. Is it something that HAS to be done at this HP level? No. But the tune is the most important thing. The stock block can handle the whipple with about 450-475 to the wheels. Anything over that and it won't be Long before you see a rod though the block. With a great tune and this HP level you should be ok. But if you plan on bigger HP down the road then you'll need to build the motor.
---------- Post added at 05:50 PM ---------- Previous post was at 05:48 PM ----------
---------- Post added at 05:51 PM ---------- Previous post was at 05:50 PM ----------
Sorry about the double post. Didn't realize I messed the other post up.
340 RWHP
325 RWTQ
Old 11-22-2012, 05:56 PM   #20
Another thing that's hurting me is I didn't get the tuner when I bought the car. So the tune is locked in. Steeda says they can send me a custom tune. So when I do supporting mods, I'll need that to retune the car.
This is the first car I've ever owned that used handheld tuners and has locked in tunes. Or should I say, the first car that I've ever had with significant hp and had the money to mod
Guess I'll focus on getting tune/tuner and adding cams, ford racing intake manifold, not sure if I'll have to upgrade any of the fuel system or not. But well see
Old 11-22-2012, 06:12 PM   #21
Supporting mods?
I know you can get kits for like 6gs. Not sure beyond that since I haven't really looked in to that yet. And I shouldn't for a while lol
Old 11-22-2012, 06:13 PM   #22
Bennyhill's Avatar
Steeda.ca or Steeda.com will have the ford racing through out bearing
Bennyhill is offline   Reply With Quote
Old 11-22-2012, 06:18 PM   #23
Lol and that's not including supporting mods.
---------- Post added at 07:18 PM ---------- Previous post was at 07:15 PM ----------
I checked. Negative on that ghostrider
Old 11-22-2012, 06:26 PM   #24
If I were to get bama tuner, is that just the tuner itself? Or is that the CAI and tuner?
And if I were to get that, would I have to return the tune to the original stock tune before I put a different tune in? Cause like I said, the tune on it now is locked in and I don't have the tuner.
I just notice that Bama tuners thru AM have free tunes for life.
Old 11-22-2012, 06:34 PM   #25
Stang23's Avatar
You can get the combo package that has the cold air intake and tuner included. Or buy the tuner by itself but its a better deal to get the intake and tuner together. And you would have to set the car back to stock before uploading the new tune from bama. It's a great deal because everytime you add a new mod that requires a tune you just call bama and tell them what you've added and they will send you a new tune.
340 RWHP
325 RWTQ
Old 11-22-2012, 06:37 PM   #26
Awesome. I'll work on getting that custom tune from Steeda.
I surely don't want to be left with 1 option with a locked in tune and an unmoddable(is that a word, lol) motor
Old 11-22-2012, 06:52 PM   #27
I'm kickin myself in the arse right now cause I coulda been a lil more patient when buying my car I coulda bought any car I wanted with or without FI.
Old 11-22-2012, 09:41 PM   #28
Stang23's Avatar
Haha I hear ya
---------- Post added at 09:41 PM ---------- Previous post was at 09:40 PM ----------
Ya forced induction is fun.. Lol
340 RWHP
325 RWTQ
04:33 PM
