Frozen E Brake Line - Mustang Evolution
Old 11-27-2012, 07:34 AM   #1
BaSohol's Avatar
Frozen E Brake Line
Well it's that time of the year in Illinois, my e brake freezes and I left driving with the e brake slightly applied till it thaws, any ideas on a quick fix or just replace the lines?
I was thinking my maybe WD40 would work
---------- Post added at 09:34 AM ---------- Previous post was at 09:32 AM ----------
Any for those who don't know this problem occurs because of the stock LCA rubbing a hole in the line where moisture now collects
2007 Ford Mustang GT 5spd
Old 11-27-2012, 07:40 AM   #2
tc x 4's Avatar
I'd try the WD first to see if it helps. Can you tell if It's the cable or the shoe.
---------- Post added at 09:40 AM ---------- Previous post was at 09:37 AM ----------
If its from the hole, dry with heat gun followed by WD then plastic dip to seal it up.
Old 11-27-2012, 08:18 AM   #3
BaSohol's Avatar
It's the cable because the pad would heat up after 2min of driving
Old 11-27-2012, 08:45 AM   #4
I need a fix that too :\
Old 11-27-2012, 11:23 AM   #5
Abominable Mustang
WhoDat's Avatar
Region: Alaska
Hmmm a chafe guard or teflon tape would definitely prevent the LCA from rubbing the hole in the first place. As for repairing damage already done, I would disconnect the e-brake line and slide some heatshrink onto it and shrink it down, covering the hole, then apply the chafe guard or teflon tape to the the repaired line.
2012 Kona Blue 3.7L V6:
Old 11-27-2012, 02:21 PM   #6
tc x 4's Avatar
I bet It's where the one splits into two. It's rite above your exaust pipe, just behind the mid pipe. The steel cables are exposed and the protective coverings are open on the ends.
Old 11-27-2012, 02:39 PM   #7
BaSohol's Avatar
I believe it's where it goes thru the stock LCA cause its rubbed a hole into the line
Old 11-27-2012, 05:12 PM   #8
tc x 4's Avatar
That could be, I just noticed today that the other end of that line is like a funnel, and It's facing forward.
07:19 AM
