Dont get headers on daily driver - Mustang Evolution
Old 12-03-2012, 08:41 PM   #1
Lethal's Avatar
I replaced my gaskets and well two bolts left... Wouldn't go in straight. Tried new bolts and still same outcome. Gonna try shop guys and see if they have better luck. Anyone have any issues such as this one? I have the bbk tuned length shorties.
If so I was wondering if heads have to be pulled out or if you can get a angle drive in there at all? I'm pretty much freaking out. Haven't got to drive her for 3 weeks now.
Lethal is offline   Reply With Quote
Old 12-03-2012, 08:49 PM   #2
Silversky545's Avatar
I used copper coat on both sides of my gaskets ... Rethreaded the factory studs and I have has zero issues and I bought used hooker long tubes at that...
Knock on wood
Silversky545 is offline   Reply With Quote
Old 12-03-2012, 08:59 PM   #3
Sooooooooo you haven't driven your mustang for three weeks because you're having a problem installing shorty headers????? Lmao sorry for your luck man but that's hilarious. We installed longtubes on my car in 6 hours. That included making a video of starting it up without the exhaust hooked up. Take it to a professional.
muscledom is offline   Reply With Quote
Old 12-03-2012, 09:02 PM   #4
deadsp0t's Avatar
You need to start each bolt a couple turns in before actually tightening any of them.
That's unimpressive
Old 12-03-2012, 09:39 PM   #5
08SteedaQ350's Avatar
Gives new meaning to 'Dude, where's my car?'
It's still stuck in your garage cause of a few bolts.
---------- Post added at 10:39 PM ---------- Previous post was at 10:37 PM ----------
+1
This practice should be done with everything that requires more than one bolt
08SteedaQ350 is offline   Reply With Quote
Old 12-03-2012, 09:57 PM   #6
Took me 12 hours ....
Used mixed matched parts don't fit well
Old 12-04-2012, 03:28 AM   #7
tc x 4's Avatar
Sounds like someone's cross threaded some bolts. If so, your gona have to pull the headers back out and chase the threads with a tap. That's the reason I wouldn't let anyone else touch my car. It took me 10hrs by my self and 0 issues. You have to use a wrench on a couple bolts, that's after you've started them all a few turns by hand. If you can't start them all by hand, back up, don't go any further till you can. It takes a lot of patience to do it rite. If you don't have time to do it rite, where are you gona find time to do it over.
Old 12-04-2012, 04:13 PM   #8
Caster Troy's Avatar
Region: Hawaii
I have the BBK long tubes and I had the same issue with 1 bolt on the right back of the header. Simple fix, just use a die grinder and elongate the bolt hole, it's only a minor adjustment and will not leak.
Caster Troy is offline   Reply With Quote
Old 12-09-2012, 10:47 AM   #9
taylor98gt's Avatar
Do you have to drop the k member to install long tubes on these body styles or can you get to them with just a lift?
taylor98gt is offline   Reply With Quote
Old 12-09-2012, 11:23 AM   #10
Stang23's Avatar
You don't have to drop the k member to install the headers. Just a lift
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 12-09-2012, 11:25 AM   #11
tc x 4's Avatar
No, you have to remove the motor mounts and lift the engine.
Old 12-09-2012, 11:46 AM   #12
Yes you remove motor mounts an lift motor
And starter
Battery and battery housing
Steering shaft
Amongst many other aggravating things
Old 12-09-2012, 12:30 PM   #13
taylor98gt's Avatar
Okay thanks, I'm thinkin bout upgrading to a 05-09 gt from my 98
Old 12-09-2012, 02:34 PM   #14
I love our body style, interior, handling, color choices....
I don't not like the motor,remote mount tranny, sound of the motor, the fact it's not 5.0
Your 98.... I love everything about your year... As long as it is a 4v ... If not sell it get a newer one
Old 12-09-2012, 02:35 PM   #15
taylor98gt's Avatar
Mines a 2v, I'm between a 96-01 cobra and a 05-09 gt.
Old 12-12-2012, 12:10 PM   #16
1lowGT's Avatar
I like new edges but i would go for the 05-09. just for newer technology
Old 12-12-2012, 01:02 PM   #17
taylor98gt's Avatar
Prolly what Ima do, come spring. May get a lil bearer to drive thru the winter an go on an sell the stang
Old 12-12-2012, 02:11 PM   #18
Terminator's Avatar
What technology do the 05-09s have that the edges don't
Terminator is offline   Reply With Quote
Old 12-12-2012, 02:33 PM   #19
More valves son. We got more valves.
Old 12-12-2012, 03:09 PM   #20
taylor98gt's Avatar
I just like the interrior better really.
Old 12-12-2012, 03:28 PM   #21
Butch's Avatar
Region: New Mexico
Except for the Cobras, we got more valves รท]
I love speed and Nascar driving,,,
killing gears and dodging traffic,,,
-----NEHP---
{Never Enough HP}
Butch is offline   Reply With Quote
Old 01-13-2013, 05:39 PM   #22
Mark221's Avatar
Just had to unbolt the steering shaft on mine. Didn't unbolt or lift the motor at all
Mark221 is offline   Reply With Quote
09:14 AM
