Leak - Mustang Evolution
Old 12-07-2012, 11:58 PM   #1
Tcward's Avatar
Leak
Just hot under the car for the first time after purchasing my 07 mustang gt. There seams to be a leak near the rear differential. The forward facing portion and running forward is covered with a light oil stain. Help!
Tcward is offline   Reply With Quote
Old 12-08-2012, 12:14 AM   #2
Terminator's Avatar
Hmm my 05 has same oil stain but not sure where it came from or how long it's been there cause I recently changed my differential oil which is when I noticed it
Terminator is offline   Reply With Quote
Old 12-08-2012, 12:18 AM   #3
Tcward's Avatar
Yeah I'm not too sure how long it's been going on. I think I will just clean it up for the time being and change the fluid. See where it is coming from. Oh joy!
Old 12-08-2012, 12:26 AM   #4
gmcmanus's Avatar
Is the oil leak stain actually on the differential? I think there is a vent at the top of the passenger side rear differential that can blow out some fluid at high speeds. I've got some fluid on mine as well.
gmcmanus is offline   Reply With Quote
Old 12-08-2012, 12:32 AM   #5
Tcward's Avatar
It's actually caused the concrete below to stain. Not bad. But it can be seen where it has been slowly dripping from too.
---------- Post added at 01:32 AM ---------- Previous post was at 01:30 AM ----------
The more I think about it, the more I think I might of damaged it. I hit a deep pothole a couple weeks back and for awhile couldn't find anything wrong. Lol, apparently I was wrong.
Old 12-08-2012, 12:35 AM   #6
gmcmanus's Avatar
That sucks man, sounds like it is the pinion seal where the driveshaft connects into the differential. 2 Hour Job pretty much if you're savvy.
Old 12-08-2012, 12:37 AM   #7
Tcward's Avatar
Any idea how much the parts would be off hand? Obviously I'm not letting this areas ****ty mechanics touch my car so I will be doing it myself.
Old 12-08-2012, 12:43 AM   #8
gmcmanus's Avatar
National 3604 - Oil Seal | O'Reilly Auto Parts
I think that is it, also may want to look for metal damage when you remove the old seal in which case I think you'd need a repair sleeve which you can also get from most parts stores. $22
Old 12-08-2012, 05:46 AM   #9
Tcward's Avatar
Sweet man! Thanks for the help. I'll get under it later this week to get it done and let you know!
Old 12-22-2012, 04:58 PM   #10
Tcward's Avatar
You were right! Seal was leaking! Replaced and working like a champ!! You guys are awesome!
Old 12-22-2012, 10:09 PM   #11
gmcmanus's Avatar
Glad it worked out man, figured that's what it was
06:56 PM
