Lowering springs & suspension upgrade - Mustang Evolution
Old 12-08-2012, 09:59 AM   #1
stemar's Avatar
Ok so I just got an end of the year bonus check from work so I'm thinking about buying myself and the Mustang a few X-mas presents.
I think I'm going to go with the Ford K springs 1.5" drop I know I'm going to need a pan hard bar and some camber bolts for the front struts.
I'm going to reuse the stock struts and shocks for now because the only have a little over 20K miles on them.
I also want to get upper and lower control arms at the same time to stop the wheel hop and thats were I have some questions There are so many to choose from. Right now I'm thinking of getting ether UMI or J&M non adjustable UCA & LCAs Why because they are cheep and I'm not sure I need to spend the extra money on more expensive control arms because in reality the car will most likely never see a drag strip or autocross event. So what Im looking for is some imput as to weather my thinking is flaud or the products from these MFGs is junk or not worth the money and I should buy a different brand or something like that.
Pypes shorties, BBK catted X, Flowmaster Pro's, K&N CAI, FRPP- P springs, Steeda UCA, J&M Panhard bar, Hurst Comp plus, FR500 Wheels W/NITTO's , SCT SF3 W/BAMA 93 Race tune, Pioneer TS-D6802R speakers, chin spoiler, Eleanor style grill, GT500 rear spoiler
stemar is offline   Reply With Quote
Old 12-08-2012, 11:11 AM   #2
BaSohol's Avatar
Go for it, hold off on the panhard bar tho, I didn't need one with my ford K springs and I like my J&M LCAs
2007 Ford Mustang GT 5spd
Old 12-08-2012, 05:53 PM   #3
tc x 4's Avatar
You will need adjustable uca's with a drop to correct pinion angle.
Old 12-08-2012, 06:35 PM   #4
Turtlestang39's Avatar
Are u lowering it 1.5" even?
Turtlestang39 is offline   Reply With Quote
Old 12-08-2012, 06:44 PM   #5
stemar's Avatar
I know adjustable control arms are needed to dial in the rear suspension to get the best launch and lower your 60' times for drag racing or to dial in the pinion angle if I swaped in a 1 pice drive shaft I did not think it was something I needed just because I lowered the car but thats why Im asking questions !!! I was only installing the control arms to firm up the suspension and control wheel hop
Old 12-08-2012, 07:00 PM   #6
stemar's Avatar
not 100% sure 1.5" would be the most I would lower it Im on the fence as to
what springs I want I have it narrowed down to ether the ford K or P springs or the Steeda sport springs witch are kinda in the middle.
I don't want to lower the car to much just get rid of some of the gap. Down the road I want to swap out my stock wheels and tires for some 19x9.5 SVE Drift wheels and 275/40/19 tires witch are a little taller then stock.
Old 12-08-2012, 07:15 PM   #7
True. Yea I'm looking for new wheels tires and springs also. Might end up getting some 18s and I'm looking into the ford k or eibach pro kit.
Old 12-09-2012, 12:37 PM   #8
Caster Troy's Avatar
Region: Hawaii
Don't use the stock dampers, it's going to feel like crap. You should use performance dampers that are tuned to the lowering springs. Your car will fell better than when it was new. I went with The Eibach Pro system plus and it looks great and rides like a champ. If you don't want to spend the money on a whole system you can get the Pro system which is just the springs and dampers, I would recommend getting GT500 strut mounts which are firmer than stock, AM has them for $110 for the pair. The best price I've found on the Eibach pro system is at The tire rack, here is the link:
http://www.tirerack.com/suspension/S...oModClar=Coupe
Hope this helps.
Caster Troy is offline   Reply With Quote
Old 12-09-2012, 01:51 PM   #9
Midnight's Avatar
@ Caster Troy, the FR strut mounts work with the Eibach kit? I was ready to order the FR handling pack, but I have a perfectly good strut brace. Unless someone recommends using the new brace, I don't want to end up with a brace collecting dust or try and sell it.
Midnight is offline   Reply With Quote
Old 12-09-2012, 02:34 PM   #10
Region: Hawaii
Yes, it will, same design just a harder compound. You are going to have it out when you change springs and dampers, might as well change the mounts.
Old 12-09-2012, 08:05 PM   #11
Midnight's Avatar
Thanks Caster!
Old 12-11-2012, 07:06 PM   #12
GregC's Avatar
H&R Street-Perf. Coil-Ove
I just recently had the H&R Street-Perf. Coil-Over (Premium, Performance Street) put in. You can find them at the same link provided above for the Eibachs. They are AMAZING.
I also had my '08 vert lowered 1&3/4" and installed some Kenny Brown upper & lower control arms, anti-squat brackets, an adjustable panhard bar, and camber bolts. This was the best money I ever spent on a car, and I would advise you to get the best suspension parts you can afford. There appears to be a big difference in the quality of shocks in particular.
You may also want to look at stiffening/bracing your chassis and strut towers for better handling too.
Name:	Photo Nov 30, 12 57 13 PM.jpg
ID:	80573   Click image for larger version
Name:	Photo Nov 30, 12 58 38 PM.jpg
Name:	Photo Nov 30, 12 59 05 PM.jpg
ID:	80575   Click image for larger version
Name:	Photo Nov 30, 4 30 59 PM.jpg
Name:	Photo Nov 30, 4 31 07 PM.jpg
ID:	80577   Click image for larger version
Name:	Photo Nov 30, 5 58 32 PM (1).jpg
GregC is offline   Reply With Quote
Old 12-11-2012, 09:10 PM   #13
stemar's Avatar
I guess maybe I will just hold off a little longer and stash a few more bucks so I can do all the suspension work at one time I was planning to do Koni STR.T struts & shocks later down the road along with Strano sway bars but instead of being impatient I'll just hold off a little longer and do it right the first time
Old 11-13-2013, 02:21 PM   #14
GregC's Avatar
Any update? Hope you got something good or are getting closer.
Old 11-13-2013, 02:51 PM   #15
stemar's Avatar
Yep I went with FRPP P springs "1 drop and I installed new struts and skocks just OEM replacements MONRO I also installed new GT500 strut mounts and a Steeda UCA The car ride's
GREAT I also did 1" wheel spacers to push the stock 18x8.5 Fan-blade wheels out closer to the fender lip I plan to install an FRPP sway-bar kit down the road to finish everything up on the suspension
02:15 AM
