Battery light??? - Mustang Evolution
Old 12-09-2012, 04:53 PM   #1
Jayjay's Avatar
Battery light???
Now second day the battery light and check charging system message have been appearing and going away.... Car runs fine and all. They pop up for about a min and the disappears.. What should I check for...
Tomorrow ima stop by autozone to check my alternator and on thu ima stop by ford dealer to oil change
Jayjay is offline   Reply With Quote
Old 12-09-2012, 04:56 PM   #2
Terminator's Avatar
I would say alt. since thyre known to go bad on us
Terminator is offline   Reply With Quote
Old 12-09-2012, 05:25 PM   #3
Could be either battery or alternator. Lots of people, including myself, have had problems with the alternator.
muscledom is offline   Reply With Quote
Old 12-09-2012, 06:32 PM   #4
Jayjay's Avatar
Hope its not the alternator Don't think is cover under warranty since its an 06, I just put in a new battery 2 months ago . 😟 More money
Old 12-09-2012, 06:41 PM   #5
Hope its not the alternator Don't think is cover under warranty since its an 06, I just put in a new battery 2 months ago . dde1f More money
They're not that bad man. I think I paid like 120 for a rebuilt.
Old 12-09-2012, 06:45 PM   #6
Jayjay's Avatar
Yeah , we'll my extended warranty should cover but its 100 bucks
Old 01-12-2013, 08:40 PM   #7
Jayjay's Avatar
Took my car in finally for a routine check and oil change and also to check the alternator since the battery light comes on. Upon inspection the alternator indicated good, more testing then they found out it was becoming bad.. Also my tie rod ends are worn out and for some reason the mechanic says it also has a oil leak.
The alternator and tie rod ends are been cover by the extended warranty, I only have to pay for the alignment($85). For the oil leak I'm surprise since I just took the car 3 months ago to fix an oil leak :/ I hope it's leaking from the same place so I won't have to pay again. On Monday they should know exactly where the oil is leaking
Old 01-12-2013, 08:45 PM   #8
gmcmanus's Avatar
A lot of times the voltage regulator in the alternator will become progressively worse over time then fail completely. You'll notice things like dimming headlights when coming to a stop because it's not increasing the voltage under lower engine revolutions. Losing an alternator on the road sucks! Lost one in my 96 Crapmaro in the middle of nowhere, tried to limp it to a parts store but it shifted into 1st and wouldn't shift out. LAME
gmcmanus is offline   Reply With Quote
Old 01-12-2013, 08:56 PM   #9
Jayjay's Avatar
Yeah that sucks, battery hold its charge and car ran good. The service advisor was surprise that the battery kept its charge and I didn't get stranded since I had the light on For 3 days
Old 01-12-2013, 08:59 PM   #10
gmcmanus's Avatar
Yeah dude you got lucky, glad its squared away! Haha battery cells will probably take a dump next week now that you say that. Glass is half empty kinda guy!
Old 01-12-2013, 09:12 PM   #11
Jayjay's Avatar
Lol it's a 4 month old battery. 3 yr full replacement
Old 02-25-2013, 11:33 AM   #12
CATMAN1012's Avatar
My batter light is on after I replaced battery and alternator. I went to Auto Zone and they said battery had too much charge and alternator was good. I just drained battery and then jumped it off and light still on. Any suggested problems?
CATMAN1012 is offline   Reply With Quote
02:15 PM
