Lowing your car - Mustang Evolution
Old 12-20-2012, 02:11 PM   #1
Spaceghost's Avatar
Lowing your car
One the newer one 05-up its trick i have an friend who want to cut his coils ol sckool way....I really don't have an clue to tell him..I'm just getting in to the s197
Spaceghost is offline   Reply With Quote
Old 12-20-2012, 03:00 PM   #2
Stang23's Avatar
Do not cut the coils. That's just stupid. And the ride will be horrible. Invest in some lowering springs
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 12-20-2012, 03:13 PM   #3
Spaceghost's Avatar
Ill be sure to past it along I'm still learn about the s197 so I'm no help
Old 12-20-2012, 03:47 PM   #4
Stang23's Avatar
Ya and also it weakens the spring because your losing a coil
340 RWHP
325 RWTQ
Old 12-20-2012, 03:52 PM   #5
1slosix's Avatar
im not sure if 05+ springs are linear or progressive...but if they are like 79-04 springs cutting is ok and normal to do...you aren't weakening the spring to an extent...personally testing this i've found 3 coils is the limit before the rate is shot. on 99-04's a good cut is 1.25 coils off the front and 1 coil off the back. using a cutting wheel of course and not a torch. that's where people go wrong and horror stories start...using a torch to heat the coils changes its temper which destorys its rate.
OP no matter what you do just make sure you take your time and enjoy. Check out AM as well...they are running great prices on lowering springs for christmas...also keep researching online and see if 05+ springs will cut the same as every other mustang. good luck
carving corners like a boss
Old 12-20-2012, 04:00 PM   #6
Spaceghost's Avatar
My other 3 sn195 I cut them but I have no clue I'm learn about them...I need an book for dummy on it
Old 12-21-2012, 02:54 AM   #7
mustang06gt's Avatar
1 coil in the front and 2 coils in the rear for perfect drop. Gives you 1.25" drop in front and 1.75" in rear. Anymore than that and you will need an adjustable Panhard bar, CC plates, bolts, etc.
Or, you can just buy some TEIN S.Tech lowering springs for 200.00 like I did and get almost same drop and a lot better quality ride...
---------- Post added at 05:54 AM ---------- Previous post was at 05:53 AM ----------
By the way...
None of my current pictures show my car with the springs on yet. So don't try and compare it.
mustang06gt is offline   Reply With Quote
Old 12-21-2012, 06:58 AM   #8
Loc: Austin,TX
Do it the right way and pick up some springs. Thats just my opinion though.
Old 12-21-2012, 07:01 AM   #9
Lorraine's driver
ab_mach1's Avatar
^This
Instagram: @ab_mach1
Old 12-21-2012, 07:29 AM   #10
Stang23's Avatar
Ya it's not worth it to cut corners on this. Just get lowering springs and be done with it
340 RWHP
325 RWTQ
Old 12-21-2012, 07:50 AM   #11
buy good springs dont go cheap and dont cut yours, some you can cut those dont do it
Old 12-21-2012, 08:47 AM   #12
austinknoll's Avatar
Don't cut. It ruins the ride quality and everything feels spongy. Just go buy a good set of eibachs or H&Rs. you won't be disappointed and they are much better springs than the factory ones ford put on.
65 Mustang coupe
306 H/C/I, holley 4 barrel, T5, Hurst Shifter, Subframe connectors, 8.8 w/ 3.55 posi, 4 piston front disc brakes, SN95 rear disc brakes, shelby drop, 620 springs, Mideye 4.5 Leaf Springs, bilstein shocks.
austinknoll is offline   Reply With Quote
Old 12-21-2012, 11:38 AM   #13
Site Sponsor
Sponsor
AMWill's Avatar
Spaceghost,
I realize you're trying to save money by having the springs cut, but there's definitely better options out there than that. I do believe the factory 05+ springs are progressive and not standard, so cutting them will affect the way the car rides.
Check out our SR Performance lowering springs if you want a quality lowering spring for an affordable price. These springs are going for $169.99 with free shipping, right now. This should help you keep a little more cash in your pocket, instead of purchasing a higher end lowering spring from the top suspension specialists, like Eibach, H&R, etc. Of course, if you want to spend a little more and get a high end performance spring, we have those too. I just wanted you to be aware of all of your options!
Let me know if I can assist you with anything else!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 12-21-2012, 02:55 PM   #14
Spaceghost's Avatar
Thanks but I'm getting info for an friend of mine he was asking me and I had no clue I have 3 sn95 and this s197 so it's new to me but I'll pass it along thanks
01:57 PM
