Eibach sportline lowering springs - Mustang Evolution
Old 12-28-2012, 11:15 AM   #1
Pimman's Avatar
So I just got them? And I'm about to install them.. But there are no real instructions with mine..
If you guys could help me out
Is it straightforward simple, just replace and done?
Pimman is offline   Reply With Quote
Old 12-28-2012, 11:17 AM   #2
DWC_SmOziLLa's Avatar
http://www.americanmuscle.com/eibach...u-install.html
Old 12-28-2012, 11:45 AM   #3
MonteCitan's Avatar
You will like them! I had to have the car aligned afterwards (excessive camber up front) but beyond that, no problems.. A little too low for a good track launch but handling and ride quality are good
2012 IS F Blue IS F Sport
2006 Mustang V6 wannabe
Old 12-28-2012, 12:00 PM   #4
Stang23's Avatar
The handling might be better but ride quality not so much. You will feel the bumps in the road more especially if your on stock struts/shocks. It will look a lot better though
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 12-28-2012, 01:02 PM   #5
wheelman's Avatar
School me more on this. Didnt know too low affected launches. Is there a best height?
wheelman is offline   Reply With Quote
Old 12-28-2012, 01:06 PM   #6
Pimman's Avatar
Thanks dudes, school me more on this! I used to be in all imports with 240s, just found the muscle side, needless to say, love it!
Old 12-28-2012, 01:40 PM   #7
03fastblack's Avatar
Good luck
03fastblack is offline   Reply With Quote
Old 12-28-2012, 10:16 PM   #8
MonteCitan's Avatar
Let's just say I installed a set of lower control arm relocation brackets, my instant center of gravity on launch improved enough to drop me 2 tenths on the 60' while changing nothing else -
There's not enough weight transfer to put the weight on the rear tires, it lifts and pushes the car on the tire rather than lifting and pushing on the tire with these lowering springs
Old 12-29-2012, 04:58 PM   #9
BenGT07's Avatar
You'll need to do caster camber plates. Some people will say you don't need 'em, but just go ahead and do it. It'll probably save you some rubber.
In the market for a Fox body...
SOLD: 2007 Performance white GT Premium.
Performance: Eibach lowering kit, SVT wheels, Steeda Camber Casters, Steeda short throw, FRPP 4.10's, Airraid CAI, BBK 62mm TB, Brenspeed Detroit Rockers, Pypes Longtubes with O/R H and Violators.
For fun: Window louvers, 15% tint, Raxiom tinted taillights, J&L Audio sub.
BenGT07 is offline   Reply With Quote
Old 12-29-2012, 05:42 PM   #10
Stang23's Avatar
+1
There definitely worth it
340 RWHP
325 RWTQ
Old 12-29-2012, 05:52 PM   #11
wheelman's Avatar
Wow, how low are you though?
Old 12-30-2012, 12:19 AM   #12
MonteCitan's Avatar
I have the same sportlines - no lower than he will be
Old 12-30-2012, 05:19 PM   #13
Labrat's Avatar
I would think that the relocation brackets are what are changing up your launch weight transfer. Just using the lowering springs by themselves wouldn't change up your weight transfer. Yes, use the caster camber plates plus also use a bumpsteer kit.
Labrat is offline   Reply With Quote
Old 12-30-2012, 06:13 PM   #14
MonteCitan's Avatar
Thumbs up
I used the relocation brackets to help correct my weight transfer - you really think lowering a car doesn't change the center of gravity for a launch?!
Old 12-30-2012, 08:29 PM   #15
Labrat's Avatar
Yes, you will change your center of gravity, but at an 1 - 1 3/4 of an inch I would think that it would be pretty subtle. But you also use the relocation brackets and that too would enhance your center of gravity and thus effect your launch. I guess what I'm advocating is that lowering your car wouldn't effect your launch in a negative way.
Old 01-01-2013, 08:54 AM   #16
Gil_T2's Avatar
Lowering you car 1 to 2 inches, does effect you launch in a negative way big time. 1 1/2 " drop could move your CG forward 12". Just take a look at any adjustable setup, the mounting holes are only 1/4" apart on some. I also gained 2 ten's in my 60ft, with relocation brackets, with a 1" drop right off the bat before fine tuning.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 01-01-2013, 04:16 PM   #17
Stang23's Avatar
So the relocation brackets for the LCAs are really worth it? I've been debating on whether or not to get them. Right now I'm running Tokico adj struts/shocks, eibach sportlines, front and rear eibach away bars, BMR upper control arm and lower control arms and BMR adj panhard bar. Would I see a benefit with the addition of relocation brackets?
340 RWHP
325 RWTQ
Old 01-02-2013, 06:40 AM   #18
wheelman's Avatar
I was totally confused about the lowering/launch statement but I see he meant that it is due to unaddressed geometry changes, makes sense now.
Old 01-02-2013, 07:01 AM   #19
Haro's Avatar
If your trying to get a better launch I would drop the upper control arms and get a panhard bar & a torque arm.
Haro is offline   Reply With Quote
Old 01-04-2013, 11:12 AM   #20
Labrat's Avatar
Lowering you car using springs won't change your IC that much. Relocation brackets will make a bigger change in you geometry and should be used. The upper control arm helps with pinion angle adjustment, if you get an adjustable one. And just about any change is better than stock.
12:14 AM
