What would it take to install a turbo on my mustang? - Mustang Evolution
Old 08-18-2009, 07:00 AM   #1
I want a single turbo and i just want the bare essentials to keep the turbo and my car running, i can't afford the whole kit right now. Just what all do i need to get the turbo in and get it running correctly. Its in a 2005 Mustang Gt that's all stock.
dooley28 is offline   Reply With Quote
Old 08-18-2009, 07:06 AM   #2
I'd save your money for a while, and build a bottom end that can handle a turbo. It would be terrible to spend a couple thousand dollars for a turbo set up just to throw a rod because the motor couldn't handle it.
arrin is offline   Reply With Quote
Old 08-18-2009, 07:42 AM   #3
There is a good deal of fabrication work necessary for the exhaust and air inlet, but it can be done if you have access to tubing bends (search for burns stainless) and silicon hose. Then you will have to tune it. www.hptuners.com has you covered there.
comhghan is offline   Reply With Quote
Old 08-18-2009, 08:14 AM   #4
It would take about 6 grand to do it right, with a kit from hp or hellion. there aren't any bare essentials to a turbo kit, you need a turbo kit plus more stuff, like a wideband, bigger fuel pump, and more. It takes alot of knowledge to install and tune a turbo car. if you want a turbo bad enough, save money and pay hellion turbo, or hp performance to put one on for you, this way you won't destroy your engine. Check out this site and start reading. Good Luck
www.theturboforums.com
imported_art is offline   Reply With Quote
Old 08-18-2009, 08:49 AM   #5
There would be a lot involved I wouldn't bother.
norbert41 is offline   Reply With Quote
Old 08-18-2009, 09:21 AM   #6
If you cannot afforded there is only one solution - buy manual or ebook about it and do it yourself.
Check the ebooks about vintage mustangs at
http://www.fordparts.org/ford_manuals.html
And also down the bottom is the insurance offer for 2005 ford mustangs if you interested:
http://www.fordparts.org/ford-car-cover/
booth is offline   Reply With Quote
Old 08-18-2009, 09:52 AM   #7
It would be a thousand or two
bour is offline   Reply With Quote
02:30 AM
