Eaton m90 supercharger mustang? - Mustang Evolution
Old 08-18-2009, 10:15 AM   #1
i have a 2005 mustang v6 4.0 and a eaton m90 supercharger i would like to put it on the car but would it fit correctly and would it work and what parts would i need to hook it up and don't say google it.
thanks
hassin is offline   Reply With Quote
Old 08-18-2009, 11:06 AM   #2
I think you can get a manifold from Ford or Shelby..
wylingford is offline   Reply With Quote
Old 08-18-2009, 11:42 AM   #3
The list of parts you'll need is long and expensive.First you'll need to see if anyone makes an intake and an intercooler for your supercharger that will bolt up to your engine.If your'e lucky enough to find that you'll also need to upgrade your fuel pump(more air,more fuel)upgrade your injectors(again more air more fuel)the wiring harness w/ all the sensors,upgrade your computer and all the misc. parts,brackets,headers and other little pieces that will make your swap work.After you get your s/c installed,you'll then need to take it to a professional tuner that will "tune"your ride as to take complete advantage of your newly installed blower.You tune your engines computer so you dont leave pieces all over the street.A good tuner that knows what he's doing will run you at least $1,000.00,probably closer to $1,500.00.If you want to go fast and not spend your kids college $$,get you a good used 4.6 from a wrecked GT.Strip out everything from it,engine,trans,harness,sensors etc.and drop it your car.Many people have done this mod,parts for the 4.6 are all over the place,you can find parts lists and other info on Mustang websites.This is a much less expensive way to go and you'll double your hp simply by going to V-8.Check it out,good luck.
lleweliyn is offline   Reply With Quote
09:38 PM
