Changing front blinker bulb? - Mustang Evolution
Old 06-04-2008, 08:54 AM   #1
Has anyone changed out their blinker bulbs? My right front blinker is out. Should the local auto parts store have the bulbs in stock? How hard are they to change? Going to do it myself instead of taking it back to the dealer.
jmy2469 is offline   Reply With Quote
Old 06-04-2008, 08:58 AM   #2
Cajun JungleBoy's Avatar
Send a message via AIM to Cajun JungleBoy Send a message via Yahoo to Cajun JungleBoy
Re: Changing front blinker bulb?
To change them is very simple.
If your mustang is a 99-04, pop your hood and where your headlight assembly is, you will see 2 metal pins. Pop them upward and out. Then unplug the headlights by simply pulling the plug (there will be two tabs to hold up on the plug to unlock it). Do the same for the blinker, and pull the headlight out. Then, to remove the bulb, twist counter clockwise i believe, and pull out. Insert bulb and all is well. Local autoparts store should have your blinker bulbs.
Cajun JungleBoy is offline   Reply With Quote
Old 06-04-2008, 09:01 AM   #3
Sorry, forgot to mention, I have a 2008 GT Convertible.
Old 06-04-2008, 09:09 AM   #4
ah... umm... not to sure, but knowing ford... probably the same
Old 06-04-2008, 10:05 AM   #5
it cant be very hard to change~ just look it up in a manual at the auto part store it will tell you which bulb to buy. Isnt the blinkers for your car below the headlamp~ it should be reach able from the underside up behind the fender well
Old 06-04-2008, 10:13 AM   #6
Yes, that is where they are. I will go after work today and pick up the bulb.
Old 06-04-2008, 10:14 AM   #7
sorry i couldn't help
Old 06-04-2008, 10:38 AM   #8
Not a problem at all.
Old 06-04-2008, 11:00 AM   #9
i havent changed one yet, but if you are having trouble reaching it, its very easy to take the bumper off, we had to pull the bumper to install a turbo.first try to go through the inner fender and from the bottom.
SimplyOrange is offline   Reply With Quote
Changing front bushings: how to? DarkShadows 1996-2004 Mustang GT 8 09-11-2009 08:23 AM
Changing fog light bulb on 2002 Mustangfan2003 1996-2004 Mustang GT 6 03-01-2008 11:07 PM
5 watt bulb? Dom Pre-2005 V6 Mustang 12 02-08-2005 06:33 PM
My blinker is having a seizure Brent Pre-2005 V6 Mustang 24 05-04-2004 02:02 PM
How many threads to screw in a bulb njstang97 Mustang Audio & Video 4 05-01-2004 06:26 PM
09:17 PM
