Rear end noise... - Mustang Evolution
Old 01-06-2013, 03:01 PM   #1
black9D5's Avatar
Rear end noise...
So I installed some rear lower control arms and now my car has developed a thumping sound whenever I shift, leave a stoplight or stop sign, and if I tap the gas you can hear it. It's definitely coming from the rear. Any suggestions?
black9D5 is offline   Reply With Quote
Old 01-06-2013, 03:06 PM   #2
nhcowboy's Avatar
What brand/type lower control arms?
1) did you possibly not tighten everything?
2) bushing type might be the issue... Rubber vs poly vs solid.
3) if there no longer is deflection in the LCA, something else might be showing slack that originally wasn't evident because of the original LCA deflection?
Idk. I'm pulling this OOMA.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 01-06-2013, 03:09 PM   #3
black9D5's Avatar
BMR poly bushings. I tightened everything. I even checked for play in the control arm. Solid as a rock
Old 01-06-2013, 07:21 PM   #4
Aggiesrok's Avatar
Did you replace the upper? Also did you grease the bushings?
Old 01-06-2013, 07:22 PM   #5
black9D5's Avatar
They're greased. No I didn't
Old 01-06-2013, 07:24 PM   #6
Aggiesrok's Avatar
Maybe the upper is loose or has a worn bushing. Could you have a bad shock that's been exposed by the stiffened LCA.
09:38 AM
