Cut bump stops with eibach? - Mustang Evolution
Old 01-06-2013, 07:30 PM   #1
maverick214's Avatar
Looking under my 06 today and I can see where the bump stops have been hitting, what looks like quite often.
Only had the car since July and I know I've hit them a couple times myself.
It has the stock bump stops and I've read people cut them down.
This normal for eibachs? Did they come with new bump stops?
I have 20s right now but plan on going 18-19 in the spring so this should help.
maverick214 is offline   Reply With Quote
Old 01-07-2013, 12:36 AM   #2
Abominable Mustang
WhoDat's Avatar
Region: Alaska
My Eibach springs came with new bumpstops, but that may be because I bought the Sportlines which provide more drop than the Pro-kits. Do you know which ones you have?
2012 Kona Blue 3.7L V6:
Old 01-07-2013, 07:54 PM   #3
Labrat's Avatar
I'm running 20" rims and I did install the Steeda bump steer kit....haven't had any problems. I have the Elibach pro series springs and I looked up on their site and neither spring set comes with a bumpstop setup. Look up the bump steer kit by Steeda....it's highly recommended for lowered cars.
Labrat is offline   Reply With Quote
Old 01-08-2013, 04:06 PM   #4
Not sure, once I found the name I didn't write down the number (I didn't know they had different ones)
Will check soon, I need to jack it up to put my TCI shifter back in.
Old 01-08-2013, 07:09 PM   #5
Labrat's Avatar
The springs are different colors. Look at yours and check the SPORTLINE | performance-suspension.eibach.com
Old 01-08-2013, 07:16 PM   #6
Thanks!
They are black so I guess they are the pro
Old 01-08-2013, 07:20 PM   #7
Labrat's Avatar
Thanks!
Check out their site....they have a lot of good info there. I thought the pro's were gray, but with out going to garage and looking to verify I can't be sure...lol! But the sportlines are red so either way it's gonna be pretty easy to tell.
08:47 AM
