Lowering Springs or Sway Bars - Mustang Evolution
Old 01-08-2013, 03:07 PM   #1
Aggiesrok's Avatar
Which is a better improvement for handling? Lowered definitely looks great, but requires, Camber plates or bolts, possibly panhard, LCA relo brackets. Upgraded Swaybars stiffen the car and are cheaper either way.
Old 01-08-2013, 03:22 PM   #2
Venomouz831's Avatar
Depends on how much of a drop you go but definately lowering springs is better. You will notice it better than sway bars
)02 Gt, Founder of WE2G
Old 01-08-2013, 03:23 PM   #3
Horseplay's Avatar
if u only do 1.5" drop u wont need cc plates. i would get springs first just becuz stock ride hight looks nasty
Low2v
Old 01-08-2013, 03:28 PM   #4
Stang23's Avatar
Go with the lowering springs. Looks and performance will be better than just getting sway bars. With just sway bars you won't notice too much.
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 01-08-2013, 07:17 PM   #5
C_Dailey95's Avatar
Wait, LCA relo brackets are required when lowering?
C_Dailey95 is offline   Reply With Quote
Old 01-08-2013, 07:35 PM   #6
2300turboford's Avatar
I springs then sway bars and definetly some Polly urethane bushings
Old 01-08-2013, 09:52 PM   #7
Aggiesrok's Avatar
That aren't absolutely required but with aftermarket LCA's it fixes the geometry unless you have adjustable ones.
Old 01-08-2013, 10:51 PM   #8
C_Dailey95's Avatar
Ohh for sure that makes sense, Thanks!
Old 01-09-2013, 09:13 AM   #9
06blackvert's Avatar
I've always heard do sway bars last out of suspensions mods (for the most part)
Springs, shocks and struts, control arms and brackets, then sway bars.
Camber bolts/cc plates when you need them and ph bar when you need it. This is all the way I understand it.
And like others have said, you shouldn't need much else for less than a 1.5" drop unless you want to go all in.
06blackvert is offline   Reply With Quote
Old 01-09-2013, 10:19 AM   #10
Aggiesrok's Avatar
I guess shocks right after springs. I've got 98K. I don't want to go more than 1.5", It's a CalSpecial and the front lip is already 1.5" lower than stock.
Old 01-09-2013, 10:51 AM   #11
I bet p springs would do it for you. Or steeda sports. It's probably time to replace your shocks and struts anyways! I'm going with the ultralites and I have the CDC aggressive chin, so it should be interesting... Haha pretty much a snow plow that'll be very close to the ground
Old 01-09-2013, 01:26 PM   #12
Aggiesrok's Avatar
In the summer it'll keep the cats out from getting under the car on the road.
Old 01-09-2013, 02:20 PM   #13
That's for sure. Haha and sticks and bugs and pennies
07:49 AM
