Brake Light & ABS Light on. - Mustang Evolution
Old 06-26-2008, 02:06 PM   #1
I have a 2006 Mustang Gt. It was in an accedent. I had to remove the engine and replace the frame rails. When I put everything back together I am now getting an constant Brake light and ABs light. I first assumed that after I bleed the brakes they would go out, since I had to remove the front brake lines to replace the rails. But they did not go out. Do these lights come on and then need a scanner to turn them off or will they go off when the problem is corrected? I checked all the fuses and they are OK. Fluid level is good and I bleed the system.
stevinas is offline   Reply With Quote
Old 06-26-2008, 02:21 PM   #2
Re: Brake Light & ABS Light on.
bleed the mastercylinder like 6 times, and then the brakes 6 times, they will go off when the problem is fixed.also make sure your power steering level is right.
trust me i know all about brake failures
SimplyOrange is offline   Reply With Quote
AbS light 2000StangLover Pre-2005 V6 Mustang 2 09-02-2008 01:44 PM
ABS light slick Pre-2005 V6 Mustang 5 04-04-2008 11:31 AM
GT Spoiler, 3rd brake light & headlights ridenmystang Mustang Parts for Sale and Wanted 7 09-25-2006 12:46 PM
99+ Third Brake Light -- Lens & Bulbs -- Like NEW Shahrum Mustang Parts for Sale and Wanted 0 04-15-2004 02:49 PM
03 Cobra Wing & Brake Light Shahrum Mustang Audio & Video 7 03-16-2004 05:43 PM
10:16 AM
