Brake, ABS & Instrument Cluster - Mustang Evolution
Old 06-28-2008, 07:45 PM   #1
I have a problem with my 2006 Mustang Gt. When I turn the car on the ABS and Brake light are on. They do not go out.After checking the parking brake switch, peddle switch and low level switch found them all to be OK. I then found a bad ground on Abs Module and repaired it. The light are still on. So I continue working my way up. Through the smart junction box which appears OK. I was sure it was the harness from the SJB to the Cluster or the cluster it self. So I took the cluster out of my 08 mustang a swap them. When I put the 08 cluster in the 06 The brake light came on and then when out after self check as normal. The Abs light did not come on at all. When I put the 06 cluster in the 08 the Brake light and the ABS light stayed on as it did when it was in the 06. This is leading me to believe the cluster is bad. But when I think of it further the 06 has Abs and the 08 does not. Now follow me here. If the 06 got an ABs code and that code is saved in the cluster not the pcm, and the code needs to be cleared by a scanner at the dealer then it might just stay on when switched to the 08. And maybe the 08 cluster is not programed for ABS(even though the light is installed) since the car does not have ABS so that is why it does not come on when installed in the 06 at all. So my questions are:
Is the cluster programed for the options the car has "ABS"?
Are the codes stored in the cluster?
Do the codes need to be cleared after the repair is made or will they clear?
Or do you think I just need a cluster?
stevinas is offline   Reply With Quote
Old 06-28-2008, 08:21 PM   #2
05RedDevil's Avatar
Send a message via AIM to 05RedDevil
Re: Brake, ABS & Instrument Cluster
The codes would have to be stored in the PCM. From the sounds of it, I'd have to say that the cluster was bad.
Are you planning on taking it to a stealership or just leaving it?
Some show. Some go.
462 rwhp/ 446 ft-lbs
05RedDevil is offline   Reply With Quote
Old 06-28-2008, 08:31 PM   #3
I need to get them working. I have to have the car inspected. I will just buy a new cluster, I assume the dealer will charge me a furtune to program it with my correct odometer reading.
Old 06-29-2008, 11:34 PM   #4
Scut95's Avatar
if you have a warranty it would probably be covered under that....other wise they will probably charge an arm and a leg
Old 07-01-2008, 08:53 AM   #5
05RedDevil's Avatar
Can't you at least find the part from a salvage yard and then just pay for the tune?
Some show. Some go.
Instrument cluster swap ponyboy94 Pre-2005 V6 Mustang 17 09-28-2010 06:09 AM
instrument cluster gages dd96stang Pre-2005 V6 Mustang 3 08-02-2010 08:47 AM
Need help on Instrument cluster. Batroo 1979-1995 Mustang GT 4 04-23-2008 09:48 PM
instrument cluster swap pipeguy General Mustang Discussion 0 04-11-2008 09:43 AM
94 - 95 GT Instrument Cluster StreetRacer4371 Mustang Parts for Sale and Wanted 5 10-21-2004 08:32 PM
08:22 AM
