Parking break HELP? - Mustang Evolution
Old 01-18-2013, 09:09 PM   #1
silverstang831's Avatar
Parking break HELP?
I need help with my parking break "hand break"? How do I adjust it? I pulled it as far as I can and when im parked on an uphill it moves. I just put it in 1st gear and problem solved but I know my parking break needs to be adjusted.
silverstang831 is offline   Reply With Quote
Old 01-18-2013, 09:38 PM   #2
maldog's Avatar
Region: Nevada
The Ford Mustang's braking system is an important safety element. One of the car's braking components is the parking brake, or hand brake, which is located inside the car. The parking brake is easily engaged by pulling up the handle and it is often used when the vehicle is parked.
M/F*Park the car on a level surface and turn off its ignition. Open and secure the car's hood. Disconnect the negative cable from the vehicle's battery, using a wrench. Enter the driver's side of the car. Position yourself at the Mustang's center console. Insert a flat-head screwdriver between the spaces of the parking brake cover and remove it carefully. Pull up on the parking brake handle to the fourth notch.
M/F*Remove the bolts inside the parking brake assembly, using a wrench. Locate the adjuster nut connected at the base of the brake cable rod. Loosen the nut and ensure the cable rod remains attached. Push the parking brake's button and fully lower it.
M/F*Turn the adjuster nut with a wrench until it is completely tightened and located close to the parking brake handle. Ensure the cable rod is in its original position. Pull up and push down the parking brake handle four times to set the adjustments. Reinstall the brake assembly's bolts.
M/F*Apply lubricant to the assembly to maximize adjustment effects. Replace the parking handle cover. Reconnect the negative battery wire and close the hood. Start the engine and test the parking brake to ensure it engages and properly works.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 01-19-2013, 12:50 AM   #3
Thanx! Very helpful i appreciate it!
Old 01-19-2013, 08:36 AM   #4
maldog's Avatar
Region: Nevada
No problem
Old 01-19-2013, 05:23 PM   #5
maldog's Avatar
Region: Nevada
Also, the panel they are talking about you lift up the center console door and on the left front area you will see a small plastic panel, maybe 1" 1/2 by 2" this is where you gain access.
Old 01-26-2013, 09:05 PM   #6
THANX BRO haven't had time to fix my parking break I will try this tomorrow doesn't sound to difficult
Old 02-10-2013, 04:35 PM   #7
Mark221's Avatar
Yeah thanks to mine is getting a little light too
Mark221 is offline   Reply With Quote
02:26 PM
