Parking break - Mustang Evolution
Old 01-22-2013, 08:47 PM   #1
Ashamoon's Avatar
Parking break
I was parking on a hill And I pulled my parking break and I heard a loud snap and now the parking break doesn't work and I'm guessing its the hand brake line. Anyone know an average cost to fix this ?
Ashamoon is offline   Reply With Quote
Old 01-23-2013, 08:58 PM   #2
gmcmanus's Avatar
Parts are going to run you about $220 I believe is what I paid for my cable. It was a ***** to install with just 1 person so you might consider having a shop do it... The e-brake cables are known to freeze on earlier S197's
gmcmanus is offline   Reply With Quote
Old 01-24-2013, 04:21 AM   #3
maverick214's Avatar
Yep something with them not sealing. I replaced one on my 2005 because it froze. When I got the old one off rusty water poured out from inside the cable. I believe they are redesigned now.
maverick214 is offline   Reply With Quote
Old 01-24-2013, 05:58 AM   #4
610swolf's Avatar
Mine snapped as well, lucky my car was under warranty. I was wondering though if it is possible to replace the oem cables with the wildwood ones from AM? Is that cable any better, has anyone ever tried it?
610swolf is offline   Reply With Quote
Old 01-24-2013, 06:01 AM   #5
The Blue Dragon
GrabberBlue5.0's Avatar
I can't imagine that wilwood makes a better ebrake cable, it's not a performance part, unless you're a drift racer. However I can't imagine it's bad either, it's wilwood.
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 01-24-2013, 07:35 AM   #6
Send a message via AIM to Borii
Check all four corners of the linkage and then check in the console. It has points where it is mounted which, should it come off or break off without actually breaking the cable, you will have enough slack to make it useless. Might be as simple as reattaching.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 01-24-2013, 08:55 PM   #7
gmcmanus's Avatar
I think if you order an OEM cable from Ford that its the exact same cable that is on the new Mustangs 11+ at least that is what I was told. They improved the silicone and boot design where it compresses near the caliper.
12:13 AM
