My current/ proposed build list - Mustang Evolution
Old 01-28-2013, 04:22 PM   #1
Wolverine0587's Avatar
I've decided to take the long road of creating my own 'Boss' mustang, Boss 281 to be precise. I'll list here my current list of upgrades and then my proposed. Just looking for some suggestions on the proposed i.e. what manufacturer or even different upgrades all together.
Current:
FRPP CAI
FRPP Hot Rod Cams
Kooks long tube headers, High-flow cats and X mid-pipe
Pypes Violators axlebacks
PA Performance High Output Alternator- 200 Amp
Proposed:
FRPP Intake Manifold
3.73 gears
FRPP CNC Ported Heads
Ford Racing 62mm TB or GT500 TB
TCI Streetfighter Torque Converter
Coil over suspension
brake upgrade
and all upgrades that need to go along with these in order for them to work properly and efficiently.
I am definitely looking to keep this car naturally aspirated although I have considered a S/C somewhere down the line, but not for a long time, if ever.
Wolverine0587 is offline   Reply With Quote
Old 01-29-2013, 08:59 AM   #2
Send a message via AIM to Borii
With your cams and then the possible addition of the manifold, 3.73s, as you already stand is weak. I would say 4.10. 4.30 would be more ideal.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 01-29-2013, 09:18 AM   #3
Stang23's Avatar
+1
Ya I would go 4.10s especially if your keeping it naturally aspirated
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 01-29-2013, 10:02 AM   #4
Hmmm, ok. That was a tough debate for me.
Old 01-29-2013, 11:04 AM   #5
Wait, 4.30? I've never heard of anyone using those it's always been 3.73 and 4.10.. Do remember I have an automatic, so does that change anything?
Old 01-29-2013, 11:57 AM   #6
Luna1994's Avatar
Region: Utah
I got 4.10s and I wish I would have went 4.56
Luna1994 is offline   Reply With Quote
Old 01-29-2013, 12:23 PM   #7
4.10 is usually a good blend of driveablity and torque production. 4.30 is more the former than the latter. Cams and manifolds, which make power up high, will be giving up a bit of HP if you go higher than 4.10s the more I think about it.
Sold - 2001 Audi S4
Old 01-29-2013, 06:38 PM   #8
Ok, then. Sounds like 4.10s then. Are there any power adders I'm missing? I have also planned on upgrading the fuel pump and injectors, but haven't determined how much I wanna increase my lb/hr of injection.
Old 01-29-2013, 08:24 PM   #9
Stang23's Avatar
You don't need to touch the fuel pump or injectors if your staying NA. If you were doing a blower then ya that stuff would need to be upgraded.
340 RWHP
325 RWTQ
Old 01-29-2013, 08:41 PM   #10
So unless I'm gonna go forced induction it's pointless? Or just not needed. I'm just curious if I'll see an improvement with those upgrades?
Old 01-29-2013, 10:17 PM   #11
Stang23's Avatar
It's pretty much pointless. You won't see a gain from that. Put that money towards other upgrades
340 RWHP
325 RWTQ
Old 01-30-2013, 05:15 AM   #12
GTRob504's Avatar
Skip the coil overs and look into a handling kit with struts/ shocks springs beefier sway bars and a pan hard bar. Don't forget the lower and upper control arms.
If you are doing long tubes plus all of the FRPP NA mods you should easily achieve 350 rwhp. You will loose some low end torque and HP below 4000 rpm. This is fairly well documented in MM and FF magazine . Plus it will sound much more bad *** that FI.
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 01-30-2013, 06:17 AM   #13
Ok, any suggestions where too look for these items? Brand maybe?
Darn, I was really hoping to get up to about 400
Old 01-30-2013, 06:59 AM   #14
GTRob504's Avatar
FRPP Eibach BMR UMI to name a few, all make handling kits.
As far as brake kits go, none of the big brake kits will fit on any stock wheel except for GT500 wheels. So if you are planning on a big brake kit then you have to look at doing something with your wheels
Old 01-30-2013, 07:09 AM   #15
I have a staggered set of gt500 wheels planned and I'll def look into those suspension kits.
Old 01-30-2013, 07:31 AM   #16
Stang23's Avatar
Or go on American muscle, Late model restoration, Brenspeed, etc and you'll find everything you need
340 RWHP
325 RWTQ
Old 01-30-2013, 07:39 AM   #17
350 WHP is still difficult to achieve and most likely you will not.
400 WHP can be done but NEEDS heads and NEEDS valve train work to spin high enough to produce the power. Which will in turn push you into building the lower end.
Injectors and Fuel pump WILL benefit in the heads/manifold/valve train stage, but until then, it is a dump of money.
Sold - 2001 Audi S4
Old 01-30-2013, 07:43 AM   #18
I just found the kit on AM. I've never managed to see it before now haha! And the wheels I already have sitting on my build list.
---------- Post added at 08:43 AM ---------- Previous post was at 08:40 AM ----------
Understood, Thank you for that. I can't complain becuase I already hit 321HP and 344TQ
Old 01-30-2013, 08:10 AM   #19
I mad 340WHP and 320WTQ with the following:
Detroit Rocker Cams
Pypes LT Headers/OR X/Violators
C&L Intake
CMDPs
STEEDA UDPs
4.10s.
The 4.10s are important to mention because the higher the gear, the lower the dyno output. A trade off well worth it to me.
I am hoping to make 350-355 WHP with a new, more aggressive tune and FRRP manifold. And 4.56s
Sold - 2001 Audi S4
Old 01-30-2013, 08:31 AM   #20
Alonzo.dargan1's Avatar
Detroit Rocker Cams
C&L Intake
CMDPs
STEEDA UDPs
4.10s.
You might not see that 350-355 if you go to those 4.56 gears.
Alonzo.dargan1 is offline   Reply With Quote
Old 01-30-2013, 08:39 AM   #21
I agree. I plan on running the car, before the gear swap.
Sold - 2001 Audi S4
Old 01-30-2013, 09:14 AM   #22
Hey Borii, did you have an issue with your pipes hitting the spare tire well? I just retightened them so the right one wouldn't hit anymore and by the time I got home it was at it again.
Old 01-30-2013, 09:23 AM   #23
No sir. Try turning them. Or swapping sides. My pipes don't get even close enough to hit it.
Sold - 2001 Audi S4
Old 01-30-2013, 10:14 AM   #24
I've turned the one that was hitting, but I'll try it again and turn it a little farther this time and maybe press in the corner that it's hitting a bit to give it some more clearance. If that doesn't solve the problem I guess switching is the case.
Old 01-30-2013, 06:33 PM   #25
Aha! Found the problem! Gotta shorten one of my muffler hangers
03:07 PM
