01-29-2013, 08:27 AM
#1 | | Registered User
| Major problem
Okay so my stang won't stay on thought It would of been the alt. so I swapped it out last night car cranks on just 2 min later it fights to stay on an just dies and if I put it into gear it quickly dies an jerks it's an auto by the way not sure what else it could be |
01-29-2013, 08:36 AM
#2 | | Registered User
Can you read any CEL codes?
01-29-2013, 10:08 AM
#3 | | Registered User
Maybe fuel filter needs changed.
01-29-2013, 10:34 AM
#4 | | Registered User
| Quote:
Originally Posted by rangerbert Maybe fuel filter needs changed. | No CEL codes given I changed the fuel filter along with plugs last summer and use nothing but Chevron gas so idk if it might be something else
01-29-2013, 10:47 AM
#5 | | Registered User
Charge the battery and see what's up
01-29-2013, 11:02 AM
#6 | | Registered User
I changed my alternator after similar issues and found it to be the battery after the fact. The battery just sucked even though it tested 'good' according to the load tester.
01-29-2013, 11:59 AM
#7 | | Registered User
| Quote:
Originally Posted by Alonzo.dargan1 Charge the battery and see what's up | Took battery out had it checked was at 30% now it's fully charged will plug her back in tonight hopefully that was the issue
01-29-2013, 01:25 PM
#8 | | Registered User
| Quote:
Originally Posted by Terminator
Took battery out had it checked was at 30% now it's fully charged will plug her back in tonight hopefully that was the issue | Hope that was the problem bro
01-30-2013, 10:13 AM
#9 | | Registered User
So it wasn't the battery it turns on just fine but than 4 secs later turns off I feel like it could be a sensor
01-30-2013, 10:37 AM
#10 | | Registered User
IT's strange that you don't get any CEL light or codes. Maybe the battery has a bad cell. Can you start it and have someone pull the battery cable immediately?
01-30-2013, 11:58 AM
#11 | | Registered User
| Quote:
Originally Posted by Aggiesrok IT's strange that you don't get any CEL light or codes. Maybe the battery has a bad cell. Can you start it and have someone pull the battery cable immediately? | Ill try that but I had the battery tested they said its fine
01-30-2013, 12:11 PM
#12 | | Registered User
| Quote:
Originally Posted by Terminator Okay so my stang won't stay on thought It would of been the alt. so I swapped it out last night car cranks on just 2 min later it fights to stay on an just dies and if I put it into gear it quickly dies an jerks it's an auto by the way not sure what else it could be  | Same thing is happening to my 93
01-30-2013, 12:32 PM
#13 | | Registered User
Have you recently done a tune up in which the spark plugs weren't calibrated?
01-30-2013, 02:16 PM
#14 | | Registered User
| Quote:
Originally Posted by 05MUSTANG4.0L Have you recently done a tune up in which the spark plugs weren't calibrated? | Well didn't know the Spark plugs needed calibration
01-30-2013, 02:32 PM
#15 | | Registered User
Yupp this is for a 05 v6, I didn't know either
01-30-2013, 02:36 PM
#16 | | Registered User
| Quote:
Originally Posted by 05MUSTANG4.0L Yupp this is for a 05 v6, I didn't know either | Yea before I didn't know the v6 had spark plug wires where as the v8 has coil packs
01-30-2013, 02:39 PM
#17 | | Registered User
Me neither I don't know anyone around me with a gt so i've never seen one up close
02-01-2013, 11:25 PM
#18 | | Registered User
It sounds like the fuel pump to me? Have you had the fuel pressure checked coming into the fuel rail?
__________________ 2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. |
02-01-2013, 11:39 PM
#19 | | Moddin' ain't easy...
| Quote:
Ill try that but I had the battery tested they said its fine | You need to test the charging system as a whole. You might not be getting a charge back to the battery. Or maybe a crank shaft position sensor. Just a guess.
__________________ |
02-02-2013, 02:48 PM
#20 | | Registered User
| Quote:
Originally Posted by maldog It sounds like the fuel pump to me? Have you had the fuel pressure checked coming into the fuel rail? | I was thinking the same thing I just had it towed again to my shop the mechanics there are gonna look at it
02-04-2013, 06:20 AM
#21 | | Registered User
Map sensor?
02-04-2013, 01:05 PM
#22 | | Registered User
| Quote:
Originally Posted by 06gt2fast4u Map sensor? | What is that? Lol
02-04-2013, 02:05 PM
#23 | | Registered User
| Quote:
What is that? Lol | Something they used in the early 90s which are not equipped on our cars
2007 Ford Mustang GT 5spd
02-04-2013, 05:33 PM
#24 | | Registered User
Oh lol... im more of a pushrod guy... im new to the modular thing.
02-04-2013, 05:42 PM
#25 | | Registered User
| Quote:
Originally Posted by 06gt2fast4u Oh lol... im more of a pushrod guy... im new to the modular thing. | Ya are mustangs have MAF sensors that measure the incoming air
02-04-2013, 06:11 PM
#26 | | Registered User
I knew that... they have been using maf since '89 ('88 in california). Initially I meant maf not map... my buddy put an engine out of a v8 explorer in his fox body and would not idle because maf was bad... just an idea
02-08-2013, 09:55 PM
#27 | | Registered User
After a week at my shop my mechanics can't figure it out the problem looks like it most likely get towed to the dealership that will probably cost a leg just to look at the car
02-08-2013, 10:01 PM
#28 | | Registered User
| Quote:
Originally Posted by Terminator After a week at my shop my mechanics can't figure it out the problem looks like it most likely get towed to the dealership that will probably cost a leg just to look at the car | Guarantee it. Sad day when you have a sick pony.
Tint, American Muscle louvers, Shelby 3rd Brake light cover, sequential tail lights, brake vent ring delete. Shorty antenna. JLT cold air intake, BAMA tune. VMP 2.5 S/C pulley. Ford racing shifter, SLP loudmouths.
02-09-2013, 06:03 PM
#29 | | Registered User
I would think if its a sensor you would get a code. Sounds like fuel pump to me
02-09-2013, 07:55 PM
#30 | | Registered User
| Quote:
Originally Posted by Mark221 I would think if its a sensor you would get a code. Sounds like fuel pump to me | Yea it throws o2 code but fixed that but sometimes the car runs an other times it doesn't
