01-29-2013, 11:50 AM
#1 | | Registered User
| Tinting the tail lights!
So since I got my GT about a month and a half ago I've been wanting to do the tail lights, third brake light and side markers. Well today is the day! I am about mid process right now, will post pictures later this evening!
__________________ 2006 Mustang GT Premium Satin Silver Metallic | Hurst Short Shifter | Flowmaster Axle Backs | Ford K Springs | JM Trackbar | 5 Speed Manual |
01-29-2013, 11:55 AM
#2 | | Registered User
01-29-2013, 11:56 AM
#3 | | Registered User
I did mine and they look amazing
01-29-2013, 11:57 AM
#4 | | Registered User
Did you remove your side markers in order to tint? I want to do mine...
01-29-2013, 12:04 PM
#5 | | Registered User
| Quote:
Originally Posted by MachMan1017 Did you remove your side markers in order to tint? I want to do mine... | Yes I did, I have a delrin screwdriver/chisel tool I machined and used it to pop it out. very easy to get out, and pull the connector off and you're good to go. ---------- Post added at 02:04 PM ---------- Previous post was at 02:00 PM ---------- Quote:
Originally Posted by Luna1994 | Looks good! I like the stock gas cap painted! I thought about doing it too. Just not sure yet!
01-29-2013, 12:17 PM
#6 | | Registered User
| Quote:
Originally Posted by Luna1994 | Did u buy ur wheels that color or did u paint em/ plastic dip em?
01-29-2013, 12:57 PM
#7 | | Registered User
Looks really good man
01-29-2013, 03:44 PM
#8 | | Registered User
I painted it all my self
01-29-2013, 03:57 PM
#9 | | Registered User
Just finished it up! I was able to to use compound on the marker lights and third brake light but was iffy about scuffing and using compound on the tail lights. so they have some orange peel from the clear but nothing horrible. there are three coats of vht and 5 coats clear. came out amazing looking, but to be on the safe side I'm going to let the clear gas out for a few days before polishing.
01-29-2013, 04:15 PM
#10 | | Registered User
| Quote:
Originally Posted by Luna1994 I painted it all my self | What did u paint the wheels with? I have chrome foose like urs and want them black like that
01-29-2013, 04:29 PM
#11 | | Registered User
| Quote:
Originally Posted by Gabesayegh
What did u paint the wheels with? I have chrome foose like urs and want them black like that | Are these what you had? These on mine before.
And I went to auto zone and bought some high quality grey primer and then I bought gloss black and a clear coat. And a **** ton of sand paper
01-29-2013, 04:38 PM
#12 | | Registered User
| Quote:
And I went to auto zone and bought some high quality grey primer and then I bought gloss black and a clear coat. And a **** ton of sand paper | Yuupp! Was that ur first time doing that? What's the process because I thought of plastic dipping mine and using a clear coat but I think ur way looks a lot better
01-29-2013, 04:49 PM
#13 | | Registered User
| Quote:
Yuupp! Was that ur first time doing that? What's the process because I thought of plastic dipping mine and using a clear coat but I think ur way looks a lot better | . Iv done it before for my friends but here's what I did....first I cleaned all the rims spotless and hand dried every little part and sanded all the chrome tell it wasn't shinny anymore......then you take the primer and put a mist of it over the whole rim but not covering the whole thing....then you take the primer and cover all of the rim by going line by line.....you put 3 coats of primer on then sand it lightly and put one more coat of primer then use a very fine sand paper to and do it again....then do the same with your gloss but after the 3 rd coat WET SAND with a very fine paper. After that do 2 coats of clear coat and then wet sand and do ur final coat
01-29-2013, 05:29 PM
#14 | | Registered User
Just for You BEACHMONKEY100. South Carolina Code 56-5-4510. Tail lamps required :: Lawserver
Every motor vehicle, trailer, semitrailer and pole trailer and any other vehicle which is being drawn at the end of a train of vehicles shall be equipped with at least one tail lamp mounted on the rear which, when lighted as herein required, shall emit a red light plainly visible from a distance of five hundred feet to the rear; provided, that in the case of a train of vehicles only the tail lamp on the rearmost vehicle need actually be seen from the distance specified.
__________________ 2013 Silver V6 Premium
Cargo Area Mat, Dash Carpet Cover, Satin JLT Oil Separator, Ford Racing Handling Package, MGP Black Caliper Covers, MMD Bolt On Hood Strut, Airaid CAI, Bama Tuner, BBK Catted X-Pipes, Ford Racing Sport Axle-Back Exhaust...(Not Done Yet) |
01-29-2013, 06:51 PM
#15 | | Registered User
| Quote:
Originally Posted by NewMtang Just for You BEACHMONKEY100. South Carolina Code 56-5-4510. Tail lamps required :: Lawserver
Every motor vehicle, trailer, semitrailer and pole trailer and any other vehicle which is being drawn at the end of a train of vehicles shall be equipped with at least one tail lamp mounted on the rear which, when lighted as herein required, shall emit a red light plainly visible from a distance of five hundred feet to the rear; provided, that in the case of a train of vehicles only the tail lamp on the rearmost vehicle need actually be seen from the distance specified. | Thanks for that! I actually tested that out when my lights are lit, they are visible! this is in running/parking lights. and during the day when break lights are needed. All is visible with no problem.
I do think it came out good! It looks a lot darker than it really is because of the shade and the way the sun was going down behind the house.
02-04-2013, 12:53 AM
#16 | | Registered User
Nice wheels!
02-04-2013, 08:19 AM
#17 | | Registered User
I tinted my lights like this, only the bottom half
2007 Ford Mustang GT 5spd
02-04-2013, 12:35 PM
#18 | | Registered User
02-05-2013, 08:49 PM
#19 | | Registered User
This is my 2010 next to a random 06 GT
02-05-2013, 11:54 PM
#20 | | Registered User
Is it easy to do? I thought about getting the smoked housings but it seems more cost effective to just tint... anyone have smoked? Any difference?
02-06-2013, 12:36 AM
#21 | | Registered User
| Quote:
Originally Posted by 06gt2fast4u Is it easy to do? I thought about getting the smoked housings but it seems more cost effective to just tint... anyone have smoked? Any difference? | Mine are smoked and I like em just fine! A lot cheaper
02-06-2013, 01:10 AM
#22 | | Registered User
I thought the tint was cheaper
02-06-2013, 07:19 AM
#23 | | Registered User
| Quote:
Originally Posted by 06gt2fast4u I thought the tint was cheaper | well the covers from what I have gathered from other buddies with mustangs is they pulled them off and went with either a film or vht nightshades. reason being is there were many negative effects with them that wasn't liked.
The cost for me to tint mine was the cost of acrylic lacquer which was 6 bucks since my buddy did his nitro lights and had half a can left over. then let the clear gas out and buffed with the 3 stage compounds from 3M.
02-06-2013, 09:45 AM
#24 | | Registered User
| Quote:
The cost for me to tint mine was the cost of acrylic lacquer which was 6 bucks since my buddy did his nitro lights and had half a can left over. then let the clear gas out and buffed with the 3 stage compounds from 3M. | You cleared and buffed your lights??? It looks duller then if you were just to use vht night shade
02-06-2013, 10:28 AM
#25 | | Registered User
| Quote:
Originally Posted by BaSohol
You cleared and buffed your lights??? It looks duller then if you were just to use vht night shade | Yes I cleared mine, roughly 5 coats of clear. Then used the buffet with my three compounds from 3M. it looks almost flat just with nightshades, my brothers nitro tail lights came out that way but he liked the look, I didn't. So I knew to clear.
02-06-2013, 07:12 PM
#26 | | Registered User
When I nightshaded my old car tail lights it came out glossy as the paint, I just used a light polish
02-06-2013, 07:17 PM
#27 | | Registered User
Here's my cobalt just nightshade on the tail lights, yours doesn't look shiny at all that's why I was asking what you did
#28 | | Registered User
| Quote:
Originally Posted by BaSohol When I nightshaded my old car tail lights it came out glossy as the paint, I just used a light polish | Any time I have ever used it no matter what the prep surface I have always gotten a dull/flat appearance. So naturally I just got some clear and did them that way to insure that I would get a nice glossy look after polished. Which they are, I just haven't updated the pictures lol..
