What happened? - Mustang Evolution
Old 01-30-2013, 08:04 PM   #1
C_Dailey95's Avatar
What happened?
Ok so, im driving down the street, going from 3rd to 4th gear, as soon as i let out the clutch in 4th the whole car jerks forward a tiny bit and then starts slowing down like im pressing on the breaks. It starts sounding wrong, then The wrench lights up. I turned it off for about 30 seconds then crank the key once and nothing happens. I do it again and it turns back on. It runs and the light is off but i feel like theres a loss in power and it seems like im pressing on the breaks a little bit when i let off the gas and coast.
Any ideas whats going on?
C_Dailey95 is offline   Reply With Quote
Old 01-30-2013, 08:49 PM   #2
Cmusstang19's Avatar
Have you checked to make sure the MAF sensor is fully plugged in, possibly could have gotten loose?
Cmusstang19 is offline   Reply With Quote
Old 01-30-2013, 09:06 PM   #3
C_Dailey95's Avatar
I have not, my dad looked it up and said he thinks it might be a fuel filter problem.
Old 01-30-2013, 09:09 PM   #4
That is another possibility, when I worked at ford we usually recommended replacing the fuel filter at 50k
Old 01-30-2013, 10:26 PM   #5
C_Dailey95's Avatar
Im only at like 32,000
Old 01-30-2013, 10:35 PM   #6
O that's really weird then, well those are really the only things I would think of with out a more in depth look, hopefully somebody here has had this issue with such low miles and can be of better assistance
Old 01-30-2013, 11:05 PM   #7
C_Dailey95's Avatar
Yeah i think were going to replace the fuel filter and see what happens after that. Thanks for the help though!
Old 01-31-2013, 05:20 AM   #8
Kcstunna82's Avatar
Well crap I guess I need to replace mine im at 54000.
Kcstunna82 is offline   Reply With Quote
Old 01-31-2013, 06:53 AM   #9
610swolf's Avatar
I'm at 60k and haven't replaced mine....... have to get a new battery this weekend, may as well do that too then.
610swolf is offline   Reply With Quote
Old 01-31-2013, 08:18 AM   #10
It's not me, it's you.
primer2tone's Avatar
Does it do this every time you go into 4th gear?
Old 01-31-2013, 09:43 AM   #11
GTRob504's Avatar
If it only happens in 4 th. try skipping up to 5 th and see what happens. Likely it's the 4 th gear synchro gear
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 01-31-2013, 12:15 PM   #12
C_Dailey95's Avatar
No it was just that one time.
Old 01-31-2013, 02:09 PM   #13
maverick214's Avatar
Gas pedal assembly maybe?
maverick214 is offline   Reply With Quote
Old 02-01-2013, 01:18 PM   #14
Mr. SoloDolo's Avatar
Hey Rob you live in the New Orleans area?
Mr. SoloDolo is offline   Reply With Quote
Old 02-01-2013, 03:52 PM   #15
GTRob504's Avatar
Yep up or of the lake
Old 02-01-2013, 04:01 PM   #16
2013mustang5.0's Avatar
Does it seem like the engine is like cutting off or starving for gas? Does it idile normal? It could be the injectors/valves or just a simple fuel pump. Also check the brakes they could be stuck a little bit when cold
2013 mustang 5.0 track pack(first mustang)
2013mustang5.0 is offline   Reply With Quote
Old 02-01-2013, 04:42 PM   #17
C_Dailey95's Avatar
It does seem like its been idling differnt. Sounding a little different in general.
Old 02-01-2013, 08:25 PM   #18
gmcmanus's Avatar
Sounds like fuel pump to me.
gmcmanus is offline   Reply With Quote
Old 02-01-2013, 08:32 PM   #19
C_Dailey95's Avatar
I bought a fuel filter today cause thats what my dad said it was, do you think i got the wrong part?
Old 02-01-2013, 09:06 PM   #20
Yeah for sure...... Does your muffler smoke or anything or does it like Bog like it seems like it doesn't get eanouf gas?
Old 02-01-2013, 09:12 PM   #21
C_Dailey95's Avatar
It smokes but only on a cold start. And the only time it bogged was when it first happened.
05:42 PM
