Battery Gauge A little High - Mustang Evolution
Old 02-07-2013, 02:12 PM   #1
galindojr24's Avatar
So my battery voltage had been goin about 3/4 high sometimes.. I got a nee battery a few months ago because my old one died.. So i'm guessing that now i need a new alternator? Right?
galindojr24 is offline   Reply With Quote
Old 02-07-2013, 02:16 PM   #2
Aggiesrok's Avatar
Put a meter on it and see what the actual voltage is, first. Should be around 14 volts.
Old 02-07-2013, 02:21 PM   #3
One lead to ground and the other to?
Old 02-07-2013, 02:42 PM   #4
Aggiesrok's Avatar
While it's running, you can touch the leads to the battery cables. If it's a normal voltage and the gauge reads high, then it's probably gauge related. If it's charging too high, then it's probably the alt.
Old 02-08-2013, 09:06 AM   #5
So im prety sure its my voltage regator then because i tested to alt and everything looked good
Old 02-08-2013, 11:25 AM   #6
maldog's Avatar
Region: Nevada
My gauge reads exactly the same and I have no problems.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 02-08-2013, 11:43 AM   #7
Blogger
99ford's Avatar
+1 I don't know how accurate those are
Old 02-08-2013, 11:43 AM   #8
BaSohol's Avatar
Same
2007 Ford Mustang GT 5spd
Old 02-08-2013, 12:39 PM   #9
Mmm at least it makes me fill better to know im not the only how long has your gauge read like that? Mine just started about 3 weeks ago
Old 02-08-2013, 01:07 PM   #10
Aggiesrok's Avatar
Normal range is usally just midway. Since you're charging checks out, you should be good.
Old 02-08-2013, 05:42 PM   #11
Blogger
99ford's Avatar
Mine has read that way even when the battery was dying
04:02 PM
