Spark Plug TSB From Ford? - Mustang Evolution
Old 02-07-2013, 09:26 PM   #1
galindojr24's Avatar
So i wanted to change my spark plugs on my 07gt and saw a tsb ford put out saying that if you where to take out the spark plugs they could possibly break or strip the treads? Anyone change spark plugs? Lately?
galindojr24 is offline   Reply With Quote
Old 02-07-2013, 09:32 PM   #2
Badinuf's Avatar
Do a search on YouTube. There are some good videos on there showing how to remove the sparkplugs without breaking them.
2007 Torch Red Mustang GT, Parchment Leather, Saleen Supercharger, SCT X-Cal Programmer,brenspeed.com tunes, Tuned by X-Act Dyno (Tempe, Az) 425rwhp, 4:10 Gears, Axel-back MAC exhaust, Dashhawk OBD-II Computer Monitoring System, Sequential Tail Lights, Halo Driving Lights, Eagle Eye Headlights with 6000K HID's, Clear Turn Signal Lenses, Projector Switchback Bulbs, Painted White LeMans Style Stripes, CDC Aggressive chin spoiler, Billet hood pins, Pirelli P-Zero P255 40 ZR19 wheels mounted on 2014 Mustang GT Wheels
Badinuf is offline   Reply With Quote
Old 02-07-2013, 09:46 PM   #3
Yeah ive seen a few im just sacred one will break i was hopeing for input from people
Who have removed them....
Old 02-07-2013, 11:29 PM   #4
Aggiesrok's Avatar
Just did mine about 6 months ago. No problems. Take your time spray a good amount of penetrate, I used Sea Foam. Then loosen 1/8 to 1/4 turn tighten back slightly, go again. They broke loose after a few tries. The issue is carbon build up inside the cylinder and grabbing the plug causing the ceramic to break. Read the TSB. I pretty much followed that. Lisle makes a tool for removing broken ones, it's about $70. I didn't need it. Just take your time and use anti-seize on the new ones. I don't think anyone sells the two piece design anymore. I had about 90k when I did it.
Old 02-08-2013, 01:03 AM   #5
tc x 4's Avatar
^^^ good advice ^^^
Old 02-08-2013, 09:05 AM   #6
What type of spark plugs did you put in? Oem motorcraft?
Old 02-08-2013, 09:53 AM   #7
Aggiesrok's Avatar
[/COLOR]
I put in E3 plugs. I like them, they seem to be better than stock. I'm sure this will start an argument as to which plugs are best.
Old 02-08-2013, 10:02 AM   #8
99GreenStang's Avatar
Bosch platinum +4 for me . JMO
99GreenStang is offline   Reply With Quote
Old 02-08-2013, 11:14 AM   #9
BaSohol's Avatar
Crappiest spark plug ever made!!!!! Lmao I ran those, smooth idle ya, but I was getting ready for nitrous so I changed them to NGK Rs 2 step colder and holy hell did the car do better all around, I'll never mess with those waste of money boschs again
---------- Post added at 12:14 PM ---------- Previous post was at 12:13 PM ----------
Ehh we don't have alot of choices for plugs on these 3vs so I doubt anyone will argue those
2007 Ford Mustang GT 5spd
Old 02-08-2013, 11:19 AM   #10
maldog's Avatar
Region: Nevada
Valuable info.....
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 02-08-2013, 11:29 AM   #11
That's because u can't run the +4 with nitrous . Have had no problem with them .
Old 02-08-2013, 11:35 AM   #12
they can, if they break ford charges like 100-150 per plug to fix. If you pay ford to do it and they break you still get charged the same.
Old 02-08-2013, 11:41 AM   #13
BaSohol's Avatar
I changed them b4 the nitrous, come on guy I'm smarter then that. I thought that were good too till I went to NGKs
Old 02-08-2013, 11:50 AM   #14
Originally Posted by maldog View Post
Wow thanks that video was great!!!
Old 02-08-2013, 04:20 PM   #15
NGk = Japan .
Old 02-08-2013, 04:29 PM   #16
NGk = Japan .
+1
Old 02-08-2013, 11:26 PM   #17
+1
Exactly lol
Old 02-09-2013, 05:30 PM   #18
Mark221's Avatar
Agree here did the same thing just be careful not to put to much penetrant so you don't get hydro lock I believe it says that in tsb. I used carb cleaner. Just remember if It doesn't turn don't force it
---------- Post added at 07:30 PM ---------- Previous post was at 07:28 PM ----------
+1
Mark221 is offline   Reply With Quote
Old 02-09-2013, 05:46 PM   #19
I was going to use PB Blaster??
Old 02-09-2013, 05:53 PM   #20
Mark221's Avatar
I used the carb cleaner because that is what it stated in the tsb. Pb blaster should work
Old 02-09-2013, 05:59 PM   #21
Mark221's Avatar
Carb cleaner worked great. I let them soak for an hour. Had no issues
12:37 AM
