Lost nut, shifter linkage arm - Mustang Evolution
Old 02-09-2013, 11:35 PM   #1
Charles.young10's Avatar
I lost the nut to the shifter linkage arm, the part that goes into the bottom of the actual shifter. I lost the nut that holds it down.
Anyone know the thread detail of that nut? Or a diagram to get part number?
It's not the two nuts that bolt up the back side, or the bolt that goes in the front. It's the single nut. 13mm is the size. I remember that much.
Charles.young10 is offline   Reply With Quote
Old 02-10-2013, 12:22 AM   #2
Aggiesrok's Avatar
Go to the dealer parts dept and they can look up from a diagram.
Old 02-10-2013, 07:16 AM   #3
Obviously, it's Sunday, nothing is open but hardware stores.. And it's just a nut, 45 cents at the hardware store, or 15 dollars at the dealership? Hmmm... Plus I am an hour away from the closest ford dealer..
Old 02-10-2013, 07:30 AM   #4
Just take the bolt with you so get the right thread, good luck
Old 02-10-2013, 07:45 AM   #5
Thanks, but it's not the bolt that can be just taken off. It's the part of linkage that is on the trans that the bottom of the shifter goes into. (Or at least I have never taken it off, in the 10 or so shifter swaps I have done, maybe it can be done?)
I know it's a 13mm, and I am assuming its going to an M10... But from there I can't find what I need..
Old 02-10-2013, 07:51 AM   #6
Oh ok, good luck
Old 02-10-2013, 10:14 AM   #7
Aggiesrok's Avatar
Obviously if you knew what you needed you could go to a hardware store. Some stuff you need the dealer diagram to figure it out.
Since there only 45 cents, buy the one you think it is and one bigger and one smaller. Matching strength grade also.
Old 02-10-2013, 11:20 AM   #8
Yeah, that's the issue though, I am guessing at most of it, lol. I am assuming its a fine thread. But I have no idea about a pitch. I was hoping the diagram would give me a part number to look that stuff up
Old 02-10-2013, 12:29 PM   #9
Aggiesrok's Avatar
Is this a stock shifter? What year?
Old 02-10-2013, 01:34 PM   #10
It's an 05, and I switched from the hurst back to stock. But this particular nut doesn't change for whatever shifter you use.
Old 02-10-2013, 01:58 PM   #11
Aggiesrok's Avatar
It's the single front one that goes in horizontally?
Old 02-10-2013, 03:45 PM   #12
Not the bolt that goes in the front, but the nut that goes on the shifter linkage arm underneath the actual shifter. The arm does It does go in horizontally though, and has a threaded end, that this nut (the one I lost) goes on to.
Old 02-10-2013, 07:05 PM   #13
Aggiesrok's Avatar
Have you looked through the Hurst customer install on American Muscle. It has detailed instructions and calls out the hardware sizes. Maybe it's referenced in there.
Old 02-11-2013, 09:24 AM   #14
Aggiesrok's Avatar
Is this the nut that you lost?
Old 02-11-2013, 09:35 AM   #15
Yep! I ended up have a nut that worked. Well I think it did. Haha. Hopefully it didn't strip or won't strip out. I put enough lock tight on there so hopefully it won't matter
Old 02-11-2013, 10:03 AM   #16
Aggiesrok's Avatar
Looks like it should be a M8 with a 1.25mm pitch, 1.0 mm pitch is the fine thread. Glad you got it fixed, hope it stays, locktite should do the job.
09:48 PM
