rear end whine - Mustang Evolution
Old 02-25-2013, 07:00 PM   #1
corey herron's Avatar
rear end whine
i just recently put ford racing 3.73 gears in my 06 GT and when i first started driving it to break them in, of course they were going to grind a little because they are new, but i have another problem. everytime i turn sharp at a slow speed there is a low tone whine. it only happens when i turn at slow speeds though, im not sure if it does it at high speeds cause i cant hear over my exhaust but i hope theirs nothing wrong. Please help.
New found love... the 06 GT
corey herron is offline   Reply With Quote
Old 02-25-2013, 07:05 PM   #2
If its a low whine thats normal. Usually goes away after broken in.
Old 02-25-2013, 07:12 PM   #3
BaSohol's Avatar
I would drop the pan at least to check the wear pattern and also just a quick look over, better safe then sorry
2007 Ford Mustang GT 5spd
Old 02-25-2013, 07:15 PM   #4
what im thinkin it might be is the s shape spring that hold the spider gears. i think that it could be rubbing one of the axles, could this happen. i mean when you make a turn the axles shift a little and that could be what the noise is maybe?
Old 02-26-2013, 08:12 AM   #5
Send a message via AIM to Borii
No true. PROPERLY installed gears should not whine in the least. Not even a little. Most gear installs whine because most installs are inherently poor.
My gears had 0 whine right off the bat and they are 4.10s which create more friction.
A quality gear, like Ford racing will not whine when properly installed. Period. No matter how long they last, even if "Mine whined for months" etc, they should never whine. AT ALL.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 02-26-2013, 10:04 AM   #6
Stang23's Avatar
Yep I have 4.10s installed by a guy that knows his ****. 0 wine
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 02-26-2013, 10:07 AM   #7
Lord NoMoney
This is off OPs topic but I didn't wanna start a thread. I'm gonna do a 4.0 to 4.6 swap eventually. Should I just gear my 7.5 rear end or just go ahead and get an 8.8 from a GT pretty sure option 2 is the obvious but jms
Old 02-26-2013, 10:11 AM   #8
2300turboford's Avatar
U need a 8.8
Old 02-26-2013, 10:14 AM   #9
Lord NoMoney
Originally Posted by 2300turboford View Post
U need a 8.8
Was pretty sure just wanted to hear so
Old 02-26-2013, 10:35 AM   #10
Additionally, the whine "breaks in" or goes away because it literally sands itself smooth so to speak.
Sold - 2001 Audi S4
Old 02-26-2013, 10:38 AM   #11
if they whine they were not setup correctly, but even then some brands depending on the metal make up have more noises than others~ ford racing used to be great, then motive over took their production and they can whine.
Regardless they should never grind etc, not when installed correctly
Old 02-26-2013, 11:10 AM   #12
Motive gears were hated by many for so long, I did not know Ford let them make the gears, either way, mine went in flawless.
Sold - 2001 Audi S4
Old 02-26-2013, 11:19 AM   #13
Yea, if you can find a quality installer and they KNOW what they are doing most of the times you are good, its just a risk you have to take
I would drain/fill the fluid and inspect them after a few hundred miles as well.
Old 03-01-2013, 11:54 AM   #14
06GTStang's Avatar
I had the same issue when my gears were changed to 4.10's. Low whining sound when turning at slow speeds. The issue is the clutch packs. The shop may not have put in the appropriate friction modifier/rear axle lubricant.
Here is a link to the TSB.
http://www.stangpit.com/wp-content/i...sb/05-21-2.pdf
Hope that helps ya.
06GTStang is offline   Reply With Quote
04:20 PM
