Supercharger time - Mustang Evolution
Old 03-01-2013, 11:08 PM   #1
Terminator's Avatar
Want some input on what to get found one on latemodelrestoration the Novi 1200 by Paxton which is only 2800 doesn't seem over priced or the roush m90 don't know which one would be better for daily driving an best overall
Terminator is offline   Reply With Quote
Old 03-02-2013, 04:13 AM   #2
Bennyhill's Avatar
Prob the Paxton. Depends on how much boost you want to push. I have a m90 and 9 lbs is all she is good for. But with that being said it's still a fun sc and it squeals like no other!
Bennyhill is offline   Reply With Quote
Old 03-02-2013, 09:41 AM   #3
Stang23's Avatar
You can spin the m90 a little harder than 9 lbs but not much. For daily driving, the Paxton would probably be better especially since boost doesnt really kick in till about 3 thousand rpms. But They will both be ok on the stock bottom end. Just depends how much boost you want to run but then again if you are on the stock bottom end I wouldn't go past 10 lbs.
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 03-02-2013, 10:33 AM   #4
BaSohol's Avatar
That Paxton at 2800 is just the supercharger and nothing else btw
2007 Ford Mustang GT 5spd
Old 03-02-2013, 10:37 AM   #5
Tominkc's Avatar
Send a message via Yahoo to Tominkc
Check the Procharger I-1,, Than choose!! Paxton is alright , but that is all you get!!
Tominkc is offline   Reply With Quote
Old 03-02-2013, 10:44 AM   #6
Rapinator126's Avatar
The m90 is junk if you want to make good power. They sound good though. Go with the Paxton.
Old 03-02-2013, 11:33 AM   #7
Terminator's Avatar
What else would I need injectors, pump?
---------- Post added at 01:33 PM ---------- Previous post was at 01:32 PM ----------
Well I just want to be over 400hp that's my goal to the wheel
Old 03-02-2013, 12:26 PM   #8
If all you want is a little over 400 at tires then get the m90. That's all it is good for about 430-450.
Old 03-02-2013, 12:41 PM   #9
245ciPony's Avatar
Can just the supercharger be installed?
245ciPony is offline   Reply With Quote
Old 03-02-2013, 12:58 PM   #10
BaSohol's Avatar
You'll will probably need bigger fuel injectors at the least, and maybe a fuel pump
Also you'll will need a dyno tune
Old 03-02-2013, 01:28 PM   #11
Terminator's Avatar
Does it have to be a dyno tune or can I just use my tuner from AM ?
Old 03-02-2013, 02:28 PM   #12
If you don't mind gambling with blowing your engine an email tune will be fine.
Not sure on your exact car but you might need maf, pump, injectors depending on when your factory setup maxes out
Old 03-02-2013, 03:34 PM   #13
Terminator's Avatar
That's why I'm confused since the complete kit is an extra 1k just for the upgraded fuel kit an Handheld Tuner so wouldn't that mean I would be gambling my motor if I bought the whole kit anyways?
Old 03-02-2013, 04:09 PM   #14
Maybe its a very conservative tune...you might leave 40-50hp on the table that way.
To me its worth the little extra for a custom tune
Old 03-02-2013, 04:30 PM   #15
BaSohol's Avatar
You already have a tuner right? Most dyno places use SCT anyways so you'll just be paying for the dyno time and tuning which will still come out cheaper then their canned tune they send with the kit
No point in having 2 tuners
Old 03-02-2013, 06:13 PM   #16
Caster Troy's Avatar
Region: Hawaii
I went with the Brenspeed Vortech V3 kit, you can't go wrong, it has everything you need all in one kit for a very reasonable price. If you don't have any other supporting mods you will probably be at a little over 400 to the wheels.
Caster Troy is offline   Reply With Quote
Old 03-02-2013, 06:39 PM   #17
Terminator's Avatar
That's what I was thinking no point in having 2 tuners but I do want to get dynoed after installation to see what my stang is pushing
03:22 PM
