oil drain plug?? - Mustang Evolution
Old 03-08-2013, 04:39 PM   #1
S197Miller's Avatar
oil drain plug??
Today I changed my oil. Before that I drove the car to the auto part store because I couldn't find my oil catch pan. Drove home jacked the car up and proceeded to change the oil. When I got down to the plug I couldn't get it off to save my life! I had to slowly back if off and the tighten to make sure I wouldn't break it off. After doing that for about 10 minutes the last 4 threads of the bolt were able to come off by hand. My question is what would make that bolt so hard to get off? And when I got the bolt off all the threads were messed up from me forcing the bolt out. Is there a more serious problem?
S197Miller is offline   Reply With Quote
Old 03-08-2013, 05:15 PM   #2
Wolverine0587's Avatar
Did you see any flattened threads? Maybe it was crossthreaded and straightened out near the end.
Wolverine0587 is offline   Reply With Quote
Old 03-08-2013, 05:19 PM   #3
Ubnbit's Avatar
+50.
Great answer.
If that is what it is, get a new bolt and a tap and clean the threads up where your drain plug goes.
Old 03-08-2013, 06:41 PM   #4
When we changed our minivan's oil before, that bolt would seriously not come off. We ended up stripping the bolt after 10-15 minutes and using vice grips with a breaker bar to get it off... Time before that we got it changed at the shop, they put too much oil in it so it sputtered and must have used an impact wrench at full torque to put it on.
Old 03-08-2013, 07:04 PM   #5
I have trouble trusting most oil change places because they have the tendency to hire gorillas to drain the oil then they screw up the plug.
Old 03-10-2013, 07:00 AM   #6
S197Miller's Avatar
Well I talked to my buddy who works at NTB and he said that happens quite a bit on Ford modular engines. So I'm not going to worry too much about it. I thought that maybe my bearings or pistons were shaving and the shavings clogged up the plug. But there were no shavings on the magnet. So it is most likely my fault from over tightening the drain plug last time.
Old 03-10-2013, 08:48 AM   #7
Gutentight is the technical term haha!
Old 03-11-2013, 07:55 AM   #8
fury88's Avatar
LOL!
I'm getting ready to change mine soon. I propped it up last night to take a look at it just in case. It's leaking a little oil but the plug seemed ok.
fury88 is offline   Reply With Quote
Old 03-11-2013, 09:22 AM   #9
Send a message via AIM to Borii
When I did my first oil change on my S197 it would not come off without serious effort in the same way you described. The threads were just fine. Screws in and out just find now.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 03-11-2013, 09:49 AM   #10
Ive broken one off (turning it the wrong way.... ) and had to have it backed out, now I am as careful as I can be and never over tighten it (snug is all you need)
11:11 AM
