Running lean - Mustang Evolution
Old 03-10-2013, 04:05 PM   #1
Djw05gt's Avatar
Running lean
I just installed bbk shorty headers, bbk catted x pipe, borla atak catback exhaust, jlt series 3 cold air & sct sf3 tuner with custom tune from bama..
Now my check engine light is on & code says I'm running lean??
Djw05gt is offline   Reply With Quote
Old 03-10-2013, 05:37 PM   #2
BaSohol's Avatar
Data log the car with your tuner then send it too Bama or tell them to re write it
2007 Ford Mustang GT 5spd
Old 03-11-2013, 05:30 AM   #3
GTRob504's Avatar
Ok so the simple questions , did all of the O2 sensors get installed back correctly? What about the CAI ? Check the bottom side of the throttle body to make sure the inlet tube is positioned over the lip of the TB. These are two very common things. Next to that you make need your rear O2 sensors turned off with that set of cats. Check with AM
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 03-11-2013, 10:20 AM   #4
Site Sponsor
Sponsor
AMWill's Avatar
Djw05gt,
Sorry to hear you're having issues with the new setup! Lets see if we can trouble shoot this lean code, and make sure it's nothing mechanical.
Have you gotten a chance to over look the exhaust thoroughly and make sure there aren't any leaks? A small exhaust leak between the header flange and down pipe will easily cause a lean code. Also, make sure you re-torque all of the header bolts after a few heat cycles. This is required for any header installation with new gaskets. An exhaust leak could very well be coming through header primary tunes flange, if the bolts haven't been re-torqued.
Also, I'm assuming all 4 of the O2 sensors are plugged in? There should be one before and after each catalytic converter.
Let me know if you've checked these things and if not, give it a try and get back to me after another test drive. Then we'll go from there, depending on what your results are!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 03-11-2013, 10:43 AM   #5
dont drive the car hard at all until you get it figured out as well
Old 03-11-2013, 06:55 PM   #6
Djw05gt's Avatar
Thanks everyone for the advice.. I started with the easiest & checked the cold air & it made the most sense to me because when I installed cold air directions said no more the finger tight on hose clamps & you just can't get a hose clamp very tight with your fingers.. So I tightened with screw driver & engine light has been off for 60 miles
Old 03-12-2013, 12:47 PM   #7
Site Sponsor
Sponsor
AMWill's Avatar
Djw05gt,
It definitely sounds like you found the leak. The intake couplers need to be snugged up pretty tight to avoid any air leaks.
At least this was a quick and easy fix. Everything should be smooth sailing from here!
Shane
Old 03-15-2013, 09:47 PM   #8
Djw05gt's Avatar
Ok the check engine light was off for a bit, but now it is back & it's coming up as a bad cam position sensor.. So I'm liking for more advise? Wasn't really expecting to upgrade my car & the check engine like on every other time I take it out
Old 03-15-2013, 09:53 PM   #9
Aggiesrok's Avatar
Switch the sensors right for left, clear codes and check again.
Old 03-15-2013, 09:59 PM   #10
Djw05gt's Avatar
Is this a pretty simple task& are these sensor located just under valve covers each side
---------- Post added at 08:59 PM ---------- Previous post was at 08:55 PM ----------
Ok is this an easy task? & are these located just under the valve covers each side of motor?
Old 03-15-2013, 10:17 PM   #11
Aggiesrok's Avatar
Yeah, on the front face of the engine below valve covers. One screw each, I think 10 mm. If the problem moves, then replace sensor. Is your oil level correct? Variable cam timing uses oil pressure to change the timing.
Old 03-16-2013, 09:14 PM   #12
Djw05gt's Avatar
Ok switched the sensors, reset the check engine light , checked the oil& still came up with the same code.. Is there anything else I mite be able to trouble shoot..
Ps. I have very little mechanical knowledge
Old 03-17-2013, 11:13 AM   #13
Aggiesrok's Avatar
Which code exactly? It didn't change from left to right or vice versa?
Old 03-17-2013, 12:52 PM   #14
Djw05gt's Avatar
Code is p0340 (circuit bank 1 or single sensor )
Old 03-18-2013, 06:44 AM   #15
Filf's Avatar
Have your alternator tested. That is a common code that gets thrown when your alternator is about to go. Alternators are a known issue on these cars as well.
Filf is offline   Reply With Quote
Old 03-18-2013, 07:29 AM   #16
Stang23's Avatar
+1
These alternators don't last too long on these cars. Had to replace mine at about 55k
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
07:54 AM
