Car will not start **NEED HELP** - Mustang Evolution
Old 03-17-2013, 02:46 PM   #1
Need some helpful advice. Car will not start. It doesn't even crank. I still get power to all of the car's electronics though. Car is a 2008 Mustang GT with a 5-speed. About 54K miles.
List of mods are:
Pypes long tube headers
Pypes shorty H-pipe & Pypes pype-bomb muffler delete
No cats & no mufflers
BBK CAI
GT500 Throttle body
RAM Clutch & RAM Steel Flywheel
Hurst Billet Shifter
SCT Bama Tune from American Muscle with 93 octane
I was driving, then heard a loud screeching noise. I pulled over within a few blocks once I knew my car was making the noise. After I cut the car off, it never started back up again.
Checked oil level...oil level is fine.
Removed the battery and had it tested. Works fine.
Checked all the battery terminal connections. All good.
Removed the starter and had it tested. Works fine.
Raised the rear wheels off the ground, put the car in neutral and rear wheels spun freely....so the problem isn't in the rear end gears.
I tried to manually turn the crank from the front of the engine with a socket wrench, but crank did not budge. The car is in neutral, so the crank should turn freely....but it doesn't. I even removed the accessory pulley belt thinking maybe an accessory pulley froze. All pulleys spin freely....except for the crankshaft pulley.
Something is preventing the crank & flywheel from turning and starting the car. At this point, I'm starting to think I might have internal engine damage or a broken oil pump. But before I start tearing my engine apart I want to get some insight on possible causes & solutions. Anyone has any insight?
jazzystang is offline   Reply With Quote
Old 03-17-2013, 05:00 PM   #2
BaSohol's Avatar
Maybe the starter some how came out and seized? Idk it's just a guess but a cheap one. Fits the description.
2007 Ford Mustang GT 5spd
Old 03-17-2013, 05:14 PM   #3
It's not the starter. That was my first guess. Removed the starter and had it tested it at 3 different auto parts stores. Starter is working just fine.
Old 03-17-2013, 05:16 PM   #4
BaSohol's Avatar
Oh sorry I didn't read that part, drain the oil and check for star dust :/
Old 03-17-2013, 06:36 PM   #5
BaSohol's Avatar
Also check the flywheel bolts one could of vibrated loose
Old 03-17-2013, 07:36 PM   #6
maverick214's Avatar
Pull the plugs out and try moving the crank again, you won't be fighting compression. Make sure your in neutral.
But sounds like clutch or flywheel bolts came loose.
maverick214 is offline   Reply With Quote
Old 03-17-2013, 09:17 PM   #7
Send a message via AIM to Borii
While this is definitely a strong possibility, it is still possible the crank doesn't turn because the engine failed and is physically seized. Hopefully not.
Used 3V engine and tranny combos are not that much these days in a worst case scenario. Not trying to be a negative person but if it failed and you end up having to dump 2-3k to fix it, might as well build it.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 03-17-2013, 11:10 PM   #8
Aggiesrok's Avatar
Have you pulled the valve covers to see if you broke a cam pulley or something jammed one of the timing chains?
Old 03-18-2013, 01:55 AM   #9
Tyoung68's Avatar
Take the belt off amd try to spin it
Old 03-18-2013, 05:39 AM   #10
DaBluedude's Avatar
Yeah, I'm gonna be the cynic here. That high pitched sound could be a bearing saying bye bye and now you're seized. But check for a top end failure first obv. I would take it as an excuse to teardown and build the engine tho haha.
2003 Mach 1
Old 03-18-2013, 06:21 AM   #11
Filf's Avatar
Wish you the best but that sounds like your engine seized
Filf is offline   Reply With Quote
Old 03-18-2013, 07:23 AM   #12
Skulls98GT's Avatar
The scratching sound as mentioned earlier could very well be the flywheel conning loose and frying your clutch. Or you may have spun the main bearing.
Should be an inspection plate on your bell housing to check your clutch.
It is best if you pull the plugs to try and turn over the motor manually to see if it is seized.
Also can drain the oil and run a magnet through it see if you get shavings.
Skulls98GT is offline   Reply With Quote
Old 03-18-2013, 01:02 PM   #13
Haven't pulled the valve covers yet. Was trying to look into some other possibilities before I open anything up in the engine. But that's definitely on my list of things to try and check.
---------- Post added at 02:02 PM ---------- Previous post was at 02:01 PM ----------
Tried that. crank still wouldn't turn and all of the accessory pulleys spun freely too.
Old 03-18-2013, 02:06 PM   #14
My bet is still clutch/flywheel, something came apart and is jamming. Only say that because they have been changed.
If not then ya probably bearing.
I'd be pulling transmission and checking it out.
Old 03-18-2013, 02:33 PM   #15
Tyoung68's Avatar
Have you pulled the plugs yet?
Old 03-18-2013, 04:14 PM   #16
garbill2003's Avatar
I would start with pulling the trans out and the valve covers. As much as I hate to say you have a major problem and should think about pulling the engine out. Do you have access to a car lift?
garbill2003 is offline   Reply With Quote
Old 03-18-2013, 04:25 PM   #17
NewMtang's Avatar
TRY THIS, HOPE IT HELPS!
Put the lime in the coconut and drink it all up
You put the lime in the coconut and drink it all up
You put the lime in the coconut and call the doctor woke him up
I said Doctor! Is there nothing I can take
I said Doctor! To relieve this bellyache
Oh let me get this straight
Oh mister Doctor man I think I'm going insane
My girl's been creepin' on me and my heart is filled with pain
Now I can't sleep, can't eat, can't stop this funky beat
Can't you hear it she keeps playing in my head
Baby You really drive me coconuts
Tell me, what am I gonna do?
You put the lime in the coconut and call the doctor, woke him up
I said doctor, is there nothing I can take
I said doctor, to relieve this bellyache
My temperature is up to 103
Is there anything you can prescribe for me?
Well the doctor said "Hmmm, now let me see
just keep your body moving that's what works for me"
Baby, you really drive me coconuts
You put the lime in the coconut and drink them both together
Put the lime in the coconut and you feel better
Put the lime in the coconut and drink 'em all up
You put the lime in the coconut and call me in the morning
I can't catch myself, hey doc I'm sick
I'm feelin' all run down, I'm sinking like a brick
I've seen dots in front of my eyes
But you talk about coconuts, and you're feeding me limes?
Different remedies you're giving to me, but nothing's working
Doc, if you don't tend to me I'm gonna be the big bad wolf
And blow your house down
Put the lime in the coconut; you're such a silly one
You put the lime in the coconut and drink 'em both together
Put the lime in the coconut and drink 'em all down
You put the lime in the coconut and call me in the mornin'
Woooo Woooo
Wooo Wooo
To relieve this bellyache, I said
Oh Wooo Wooo
Is there nothing I can take I said
Wooo Wooo
To relieve this bellyache I said
Yeah Yeah
Wah Wahh
Put the lime in the coconut and drink 'em both together
Put the lime in the coconut and then you'll feel better
Old 03-18-2013, 04:35 PM   #18
angelofrat42's Avatar
Woooo Woooo
Wooo Wooo
Oh Wooo Wooo
Wooo Wooo
Yeah Yeah
Wah Wahh
You need a hobby.
angelofrat42 is offline   Reply With Quote
Old 03-18-2013, 04:41 PM   #19
99mustang99's Avatar
Sounding like it seized, happened to a buddy of mine mustang.. I'd get ready to pull it out honestly sorry to hear it man
99mustang99 is offline   Reply With Quote
Old 03-18-2013, 08:41 PM   #20
Badinuf's Avatar
Since it's a manual I would try to push start it before tearing it apart. The engine and transmission should turn freely after you pop the clutch in second gear. If it locks up and comes to a screeching halt then you have a problem somewhere in the drivetrain.
2007 Torch Red Mustang GT, Parchment Leather, Saleen Supercharger, SCT X-Cal Programmer,brenspeed.com tunes, Tuned by X-Act Dyno (Tempe, Az) 425rwhp, 4:10 Gears, Axel-back MAC exhaust, Dashhawk OBD-II Computer Monitoring System, Sequential Tail Lights, Halo Driving Lights, Eagle Eye Headlights with 6000K HID's, Clear Turn Signal Lenses, Projector Switchback Bulbs, Painted White LeMans Style Stripes, CDC Aggressive chin spoiler, Billet hood pins, Pirelli P-Zero P255 40 ZR19 wheels mounted on 2014 Mustang GT Wheels
Badinuf is offline   Reply With Quote
Old 03-19-2013, 10:06 AM   #21
Stang23's Avatar
^^ ya at this point it can't hurt to try that
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 03-19-2013, 10:36 AM   #22
Badinuf's Avatar
That's what I figured too. He's already tried turning the engine by hand and it won't budge. Using the cars weight and momentum may break it free. Just don't try to push it too fast, a couple of friends on a quiet road, about 5 mph will do.
BTW my guess is that your oil pump failed. Did you get any lights on the dash before you shut it down?
Old 03-19-2013, 11:45 AM   #23
My bros truck did something close to this and what happened the oil pump fell out in the the pan and the crank shaft sheared off so it could be something along those lines also
Old 03-20-2013, 11:49 AM   #24
Davo_281GT's Avatar
Woooo Woooo
Wooo Wooo
Oh Wooo Wooo
Wooo Wooo
Yeah Yeah
Wah Wahh
Dude........you need some help.
Davo_281GT is offline   Reply With Quote
Old 03-29-2013, 06:35 PM   #25
Finally had time to work on this problem today.
Drained the motor oil. No metal shavings or debris in oil.
Pulled out all the spark plugs. Engine still won's turn by hand at the crankshaft pulley.
Any other suggestions before I start pull out the tranny and/or motor?
---------- Post added at 07:35 PM ---------- Previous post was at 07:34 PM ----------
NO lights on the dash before I shut it down....only the loud screeching noise.
Old 03-30-2013, 03:34 AM   #26
DaBluedude's Avatar
I still think it's a sized bearing.
2003 Mach 1
Old 03-30-2013, 05:29 PM   #27
Good news!
My engine was not seized or locked up internally. Took the transmission out to find out one of my pressure plate bolts came loose and locked up the transmission/flywheel from turning. It must have got wedged up in the transmission somewhere. I was able to manually crank the engine by hand and it's turning. All I have to do now is replace all my pressure plate bolts and put everything back together.
My clutch/flywheel are fairly new and have less than 4K miles on them. So I do not plan on changing those parts. However, is it necessary for me to resurface the flywheel?
Old 03-30-2013, 05:48 PM   #28
Filf's Avatar
Awesome news. Have you found the bolt in question? Check out your flywheel and see if the bolt did any damage, if not I wouldn't resurface it since the clutch isn't getting replaced.
Old 03-30-2013, 07:01 PM   #29
Black05gt's Avatar
I would probably loc-tite those bolts!
Black05gt is offline   Reply With Quote
Old 03-30-2013, 07:52 PM   #30
Wow this guy was right!
Old 03-30-2013, 08:25 PM   #31
Yep, bolt was just rolling around in the bellhousing. And luckily no damage to the flywheel.
---------- Post added at 09:24 PM ---------- Previous post was at 09:23 PM ----------
Making sure i loc-tite the new bolts real good. Dropping the tranny all for one bolt is not something I wanna do anytime soon again, haha
---------- Post added at 09:25 PM ---------- Previous post was at 09:24 PM ----------
Haha! Looks like that guy was right....thanks!
Old 03-31-2013, 10:44 AM   #32
Stang23's Avatar
Well glad you finally figured out the problem! Now the fun part of fixing it. Lol
340 RWHP
325 RWTQ
Old 03-31-2013, 02:02 PM   #33
BaSohol's Avatar
I called it first :p
10:11 AM
