Rust on the inside of my trunk lid - Mustang Evolution
Old 03-21-2013, 06:34 AM   #1
Region: South Dakota
Hey all,
I just found out I have some rust in the inside rim of my trunk lid, I want to fix it, or at least remedy it before it spreads too much, but I'm guessing paint for "legend lime" is rather expensive, any suggestions?
Thanks!
Combatman is offline   Reply With Quote
Old 03-21-2013, 07:38 AM   #2
legend lime probably isnt bad to purchase, depends on how hard it is to mix up. Run it by a couple body shops and let them look at it and go over what it needs, after a few stops you will get an idea of what the real fix is and the cost.
Old 03-21-2013, 09:04 AM   #3
BaSohol's Avatar
If its the inside of the trunk, clean up the rust yourself, then repaint it your self, I would paint the inside of the trunk flat black or with truck bed liner, you'll save hellavcoin this way
---------- Post added at 09:04 AM ---------- Previous post was at 09:03 AM ----------
Also post a pic so we can better help you
2007 Ford Mustang GT 5spd
Old 03-21-2013, 10:01 AM   #4
I'll take a pic after I get off work, it's only on the bottom edge, so I'm thinking I might sand down the bottom 5-6 inches and then prime and paint that area black.
Old 03-21-2013, 01:55 PM   #5
This is the worst part, the rest is jut bubbling under the paint in the top few inches
Old 03-21-2013, 02:16 PM   #6
BaSohol's Avatar
Ya grind all that away then re paint, that's bad
Old 03-21-2013, 02:32 PM   #7
Would I have to repaint my entire trunk or could I jut grind a few inches past the rust and paint from there down?
Old 03-21-2013, 02:48 PM   #8
BaSohol's Avatar
Just grind it all away! It's like cancer, if you leave any it will come back
Old 03-21-2013, 02:51 PM   #9
I don't think I'm mechanically inclined enough to repaint the whole trunk, and I can't afford to pay someone else hundreds at this point
Old 03-21-2013, 03:00 PM   #10
BaSohol's Avatar
Don't repaint the outside!!!! Just clean up the area really good, get a special rust eating primer then just repaint the whole inside black with a rattle can
Old 03-21-2013, 03:16 PM   #11
Filf's Avatar
Grind all that down, prime it, and paint it. Keep an eye on it since its inside the seam it's going to come back. You may just want to check out car-part.com for a new used deck lid from a salvage car.
Filf is offline   Reply With Quote
Old 03-21-2013, 03:19 PM   #12
Jmosher461's Avatar
It's fixed now
ID:	97381   Click image for larger version
Jmosher461 is offline   Reply With Quote
Old 03-21-2013, 04:54 PM   #13
My plan is to sand down the whole back, then spray rust reformer (turns rust into not rust), then spray it down with primer till I can get a price from a place in town that mixes up colors in rattle cans.
Sound ok?
Old 03-21-2013, 05:17 PM   #14
DaBluedude's Avatar
Sound ok?
Rust remover does not revert rust back. It will just make it crumbly and it will spread. Rust is a irreversible (in terms of correction... I know you can revert iron oxide) damage. I would get a grinder (or a dremel for that small a piece with a couple little wire wheels) get rid of all the rust. Sand it with a coarse grit sandpaper then spray it with a grey primer. Don't use wonder products. They are all gimmicks.
2003 Mach 1
Old 03-21-2013, 05:35 PM   #15
Jmosher461's Avatar
I work on rust almost every day. The only way to fully get rid of rust and for it to not to come back again is to cut it out but in your case it's not so bad so get a grinder and grind it done to bare metal, and than it coarse sand paper maybe littley with 36 or 80 and than spray it with some primer in a can to hold you off. About a 15 -20 min project not long
Old 03-21-2013, 05:56 PM   #16
Yeah I was planning on grinding it down to bare metal still, I just thought that using this stuff after words and painting over it might help hold off the rust from coming back
04:38 PM
