Eng. Tune up time! - Mustang Evolution
Old 03-21-2013, 10:12 AM   #1
Wolfsbain76's Avatar
Eng. Tune up time!
Fellow Mustang enthusiasts, as the weather warms up the time comes near to start playing with my 07 GT. And now that it's at 66K, I want to do a tune-up.....
Problem: From what I have been looking up, the spark plugs are almost guaranteed to break off. Has anyone of you had problems with taking them out yourselves? At 66K, do you think I'll need to purchase the spark plug removing kit? I am NOT looking forward to a plug break
Which is better?: I'm looking into either MSD or ACCEL coils and a better spark plug, what do you guys think about MSD or ACCEL??
2007 Mustang GT
Wolfsbain76 is offline   Reply With Quote
Old 03-21-2013, 10:43 AM   #2
BaSohol's Avatar
Plugs are NOT guaranteed to break off at that mileage...... As long as you follow the proper procedure. Then forget the coil packs you don't need them, also change the fuel filter and clean the throttle body and you should be good
Also changing the trans fluid is a good idea
2007 Ford Mustang GT 5spd
Old 03-21-2013, 12:04 PM   #3
Send a message via AIM to Borii
Yes, trans fluid is often overlooked because manual cars normally do not need tranny fluid changes. It is best to do it at some point but you can literally drive a manual into the ground USUALLY forever but without cars, the manual OEM fluid is automatic transmission fluid. So definitely change it. Very easy.
The plugs, I did a 30+ hour soak and bought a breaker bar then palm bumped it until they broke lose. Painless.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 03-21-2013, 12:58 PM   #4
610swolf's Avatar
What did you soak the plugs in exactly? I'm at about 70k myself may be time for a tune up as well.
610swolf is offline   Reply With Quote
Old 03-21-2013, 01:05 PM   #5
The gray can of WD40 penetrant.
Sold - 2001 Audi S4
Old 03-21-2013, 02:07 PM   #6
Billymich's Avatar
Try liquid wrench too.
Old 03-21-2013, 03:23 PM   #7
Filf's Avatar
You need a carb cleaner or some other penetrant that will dissolve the carbon on the plug.
Filf is offline   Reply With Quote
Old 03-22-2013, 07:50 PM   #8
Billymich's Avatar
I personally love break cleaner.
Old 03-23-2013, 06:04 AM   #9
Thanks for the input, Gents! I can't believe I nearly forgot about the fuel filter! Good catch Basohol!! But, why not new coils?! If it will help with providing more umph to the spark, I say why not! Right?!
2007 Mustang GT
Old 03-23-2013, 07:59 AM   #10
Because coils are generally good for the life if the car. They provide practically no benefit for a high price.
Sold - 2001 Audi S4
Old 03-23-2013, 08:17 AM   #11
garbill2003's Avatar
Pb blaster and inforce are the best penetrating oils I've ever used. Never seen a gray can of wd 40 where do you get it?
garbill2003 is offline   Reply With Quote
Old 03-23-2013, 09:14 AM   #12
I see. Thanks!
2007 Mustang GT
Old 03-23-2013, 09:26 AM   #13
BaSohol's Avatar
Ya Coil Packs are a lot different from plug wires, essentially the same but COPs are more durable.
The reason why you'd replace wires more often is because you have more conducting area to fail, the wires run from one point then travel up to 2 feet along the motor and are exposed to more heat and vibration. Over time the insulation can wear and electricity will always take the easier route so you could have a misfire or sputter under acceleration or with all the bends in the wire and length, the core can get cracks in it raising the resistance of the wire and causing poor engine performance
With COPs it's one straights shot and the wire is insulated with a boot so you don't easily get sorted out or cracks in the core because its a straight
Old 03-23-2013, 09:45 AM   #14
Hmmm...good knowledge. So, what is making my engine sputter at low gear when trying to enter the parkway?
2007 Mustang GT
Old 03-23-2013, 09:52 AM   #15
BaSohol's Avatar
Bad fuel filter
Bad spark plugs
Dirty throttle body
Dirty MAF sensor
Dirty air filter
Not giving it enough gas or letting the clutch out to soon
Or even maybe a bad coil but they tend to go completely out not a little bit
Seeing how everything is cheap, well besides the spark plugs, it's good to start with all those before throwing 200+ dollars at the COPs that you likely don't need
Old 03-23-2013, 10:00 AM   #16
Bad fuel filter
Bad spark plugs
Dirty throttle body
Dirty MAF sensor
Dirty air filter
Oh, Ok. Easy fixes. Might as well service all mentioned above once I do the tune up! Again, thanks a lot for your help!
2007 Mustang GT
11:14 AM
