What do you guys think? - Mustang Evolution
Old 03-26-2013, 10:26 PM   #1
PACK3NPANDA's Avatar
Region: Idaho
So I have been wondering lately around how much HP and TQ should I have gained? I have an 06 GT 5 speed. I installed an Airaid race CAI, BBK 62mm throttle body, custom performance tune from my local shop "Speedo-motive", X pipe, with the mufflers taken out and made it straight pipes. I have heard the throttle body wasn't a good choice but I can tell this car is a completely different beast! I will say I was really surprised. Please let me know what you guys think! After everything it was about $1200.
PACK3NPANDA is offline   Reply With Quote
Old 03-26-2013, 10:48 PM   #2
Venomouz831's Avatar
I would say about 35 hp gain.
)02 Gt, Founder of WE2G
Old 03-26-2013, 11:27 PM   #3
Boomdizzle's Avatar
What kind of custom tune was it if it was at a local shop? Didn't they use a dyno? But i'd say with those mods 35 HP like Venemouz said is probably a good guess. Usually a CAI and the tune required brings about 20-25 HP on our 3v's so the throttle body and exhaust would give around 10 HP I'm guessing.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 03-27-2013, 03:33 PM   #4
Send a message via AIM to Destination S19
I'm going a bit more conservative. I wouldn't say anything more than between 15-25 depending on octane you went with and ambient air temp.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 03-27-2013, 05:41 PM   #5
B52Bombardier's Avatar
I think 15-25 is too conservative. You should get that from the CAI and tune alone. Plus you could expect another 15-20 from the TB and the exaust with an X-pipe. I think more like 45.
B52Bombardier is offline   Reply With Quote
Old 03-28-2013, 06:28 AM   #6
Send a message via AIM to Borii
30-35 WHP easy, but that is email tune and x pipe as the throttle body would not give you any masurable gains until you're in cams, manifold and LT category.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 03-28-2013, 07:25 AM   #7
CAI doesn't really give you anything, maybe 5 at most and the tune another 15-20. A TB isn't going to give you anything on a mostly stock car and unless its an off road x, the change from h to x won't net you anything worth noting either.
Old 03-28-2013, 07:41 AM   #8
Non tune required intakes have shown upwards of 8WHP on an S197 because the stock design is pretty crappy. But most of the power as you stated comes from the tune itself, versus the intake.
Sold - 2001 Audi S4
Old 03-28-2013, 08:18 AM   #9
We are in agreement then. So what you are saying is the CAI and tune gives you 20-25 which is what I said. I guess I should have not assumed no cats but I still think high flow cats will give you10-15. So I guess we just differ on how much is worth noting.
Old 03-28-2013, 09:30 AM   #10
hubbs's Avatar
Quick question. I have a k&n cai which I don't believe required a tune. would a tune help it still?
hubbs is offline   Reply With Quote
Old 03-28-2013, 10:06 AM   #11
Region: Idaho
Yes. A tune would definitely wake your car up. Especially if you have a CAI
Old 03-28-2013, 10:12 AM   #12
Non-tuned required intakes really give you nothing since they do not increase the amount of air flowing into the engine. The reason why some require a tune is because they're increasing the diameter of the pipe which allows more air to pass by the MAF. The tune is required because the factory programming cannot make up for the added air. Show me a dyno run that backs up your non-tuned cai putting 8hp at the wheels.
The cats on these cars are not that restrictive, the most you'll be getting from removing a cat on the S197 is about 5hp. Most people run OR pipes because they make the car louder. It was a difference game on the SN95 and NE cars that had pre cats.
Old 03-28-2013, 10:56 AM   #13
YOU made the claims that they do not provide power. The X pipes also provide decent gains. For their cost. Giving advice to the OP without providing the info is the same thing. Not busting your balls or nothing but you can't claim something and everyone is supposed to just take it in.
The K&N intake that has the slip in it to keep the car non tune required STILL showed 10WHP on brenspeed's dyno. That easy to find one. And yes, they do increase the volume of air with the open filter and the smoothed bend.
UPR X pipe has shown upwards of 10WHP. Brenspeed's own H Pipe which usually nets lower numbers by a smidge, netted 8WHP and 10lb/ft.
Fast fords got 7 and 7 from an X pipe.
Sold - 2001 Audi S4
Old 03-28-2013, 07:38 PM   #14
Region: Idaho
How is it that you guys say a tb won't do anything without more mods yet there are dynos proven that the BBK 62mm tb just on it's own gives 15WHP and 20 TQ
Old 03-28-2013, 08:43 PM   #15
BaSohol's Avatar
I'd like to see the independent dyno that shows that
2007 Ford Mustang GT 5spd
Old 03-29-2013, 07:33 AM   #16
We said it doesn't do anything unless he has cams and manifold or heads. The few TB dynos out that show gains are usually on s/c cars.
I have never seen a TB show 15whp and 20TQ, even SC
Sold - 2001 Audi S4
Old 03-29-2013, 10:55 AM   #17
Caster Troy's Avatar
Region: Hawaii
+1
Caster Troy is offline   Reply With Quote
Old 03-29-2013, 05:59 PM   #18
+1, usually a TB is never tested by itself on the dyno
Old 03-29-2013, 07:07 PM   #19
Aggiesrok's Avatar
It should be, to settle this once and for all. Also AM should dyno each CAI they sell with no other mods and settle that as well.
Old 03-29-2013, 08:52 PM   #20
Wolverine0587's Avatar
+1.5 million.
Wolverine0587 is offline   Reply With Quote
Old 03-30-2013, 08:08 AM   #21
Stang23's Avatar
Ya I agree
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 03-30-2013, 01:42 PM   #22
BaSohol's Avatar
You'd really trust them? They will make up any number to sell a part
Old 03-30-2013, 06:53 PM   #23
+1000000
Old 03-31-2013, 10:46 AM   #24
Stang23's Avatar
Perhaps that could be the case. Lol
340 RWHP
325 RWTQ
03:55 PM
