tranny problems! - Mustang Evolution
Old 04-01-2013, 11:16 AM   #1
dylanmullins's Avatar
tranny problems!
My 2005 mustang gt was stuck in reverse. So I put it on the lift and took the tail shaft off and found a role pin stuck to the magnet. So I pulled the trans and tore out apart and all pins are there and nothing looks messed up at all. Any suggestions?
dylanmullins is offline   Reply With Quote
Old 04-01-2013, 01:05 PM   #2
Davo_281GT's Avatar
Manual or Auto?
If its manual, check your Fluids, could be low, have air in the line, or slave cylinder could be going out not allowing the clutch to engage so you can pull it out of reverse. I've heard that its good to change out the slave after 80K.
If its an auto, when was the last time you checked your fluids or had it serviced?
Davo_281GT is offline   Reply With Quote
Old 04-01-2013, 03:44 PM   #3
It's a manual. I put new blocking rings and a new 2nd & 3rd gear about a year ago and when it messed up on me I find a role pin stuck on the magnet so I pulled the tranny and tore it down. All the gears look good and all the role pins are in their place. I looked over the tranny to many times to count so I just got it back together and I'm about to put it back in and see how it goes
Old 04-01-2013, 07:53 PM   #4
And it didn't go well
Old 04-01-2013, 08:32 PM   #5
BaSohol's Avatar
Ruh roh
2007 Ford Mustang GT 5spd
Old 04-01-2013, 08:38 PM   #6
I heard that
Old 04-01-2013, 11:50 PM   #7
Wolverine0587's Avatar
Only car guys can say I blew a tranny and not feel dirty.
Wolverine0587 is offline   Reply With Quote
Old 04-02-2013, 12:01 AM   #8
Haha thats great
Old 04-02-2013, 12:04 AM   #9
Tyoung68's Avatar
You sure your clutch is engaging?
Old 04-02-2013, 06:18 AM   #10
Yes sir it is
Old 04-02-2013, 09:44 AM   #11
Tyoung68's Avatar
And all your linkage is adjusted ?
Old 04-02-2013, 09:49 AM   #12
Yeah I looked over everything and everything is in place just right. I'm stumped
Old 04-02-2013, 12:30 PM   #13
Tyoung68's Avatar
So what happens when you try to change gears?
Old 04-02-2013, 12:50 PM   #14
Well when its in so called neutral its in reverse and when you put it where reverse is its in 5th then you can move it to the right and up and it goes in fourth. There is no getting it into first or second.
Old 04-02-2013, 01:19 PM   #15
Tyoung68's Avatar
Hmm sounds like somethings is bent in the transmission or maybe it wasn't together right? I know when i rebuilt mine i put a part in backwards and nothing would work
Old 04-02-2013, 01:26 PM   #16
But it worked perfect for a year or so
Old 04-02-2013, 02:46 PM   #17
Tyoung68's Avatar
Hmm well then sounds like something go bent is there any worn out bushings on your linkage?
Old 04-02-2013, 05:26 PM   #18
White03GT's Avatar
He ended up figuring it out, turns out it wasn't anything major at all😅
White03GT is offline   Reply With Quote
Old 04-02-2013, 06:02 PM   #19
It was missing a bushing. Easy fix. Thinking way to hard and I over looked it. But on the bright side it runs like a champ now!
Old 04-04-2013, 09:35 AM   #20
Davo_281GT's Avatar
(Palm Forehead)
12:57 AM
