Error code P0174 - Mustang Evolution
Old 04-02-2013, 10:36 AM   #1
Boomdizzle's Avatar
Error code P0174
I keep getting this error code when I check my fault codes. I replaced the fuel filter and cleaned the MAF sensor a few months ago and it went away for awhile but came back.
The code says that bank 2 is running lean. I checked the voltages for the O2 sensors with my obd2 and my phone and they seemed OK and each had pretty consistent voltage patterns. If anything the sensor on bank 1 was more erratic than the one on bank 2.
Anyone have any suggestions as so what it is?
---------- Post added at 12:36 PM ---------- Previous post was at 12:34 PM ----------
I hear it could also be an exhaust leak but I can't really hear any leak and I haven't seen any areas that look like they have been leaking.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 04-02-2013, 12:00 PM   #2
Boomdizzle's Avatar
Sorry, saw this had already been asked!
Old 04-02-2013, 12:04 PM   #3
sprdave's Avatar
It could also be something as simple as a small leak.
Make sure there's no cracked hoses as a small
vacuum leak can cause this code.Check to make sure
you don't have any leaks around the O2 sensors.
sprdave is offline   Reply With Quote
Old 04-02-2013, 12:20 PM   #4
Terminator's Avatar
Had same issue turned out one of the wires was being shorted out on o2 sensor
Terminator is offline   Reply With Quote
Old 04-02-2013, 01:04 PM   #5
Had this problem. Ended up being low oil level for me.
jazzystang is offline   Reply With Quote
Old 04-02-2013, 01:47 PM   #6
Boomdizzle's Avatar
Thanks for all of the suggestions guys. I'll be checking all of those tonight!
Old 04-02-2013, 02:23 PM   #7
maldog's Avatar
Region: Nevada
When I got the same code I had cleaned my air filter and over oiled it.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 04-02-2013, 06:31 PM   #8
Boomdizzle's Avatar
Yeah this first came up after I cleaned and re-oiled my filter in the fall. I cleaned the MAF and cleared the code and it went away until a few days ago. I cleaned the MAF (used a cotton swab on it also and a good amount of dirt ended up on the swab, could be it?), topped off the oil, cleared the code and tested for a vacuum leak. I didn't find a vacuum leak after spraying carb cleaner all over the intake and top of the motor, so I think that's out of the question.
I do see a small exhaust leak where my midpipe and Pypes M80's connect and lead to the catback. I may try to get that straightened out because I read that may be it.
If it comes back on I think I'm just gonna bite the bullet and put new 02 sensors in, I probably need them anway.
Old 04-02-2013, 10:27 PM   #9
maldog's Avatar
Region: Nevada
I doubt it's ur 02's? I actually tried to clean my over oiled CAI filter, but it still put the code out. So I bought a new filter at Pep Boys and I have not received any codes since then.
Old 04-13-2014, 07:06 PM   #10
Those cone shaped air filters on an intake get dirty easily,I have to clean mine everytime I change my oil.
Bluerings is offline   Reply With Quote
04:51 AM
