What should i do for maintence - Mustang Evolution
Old 04-13-2013, 11:43 PM   #1
Luna1994's Avatar
Region: Utah
Iv got an 05 mustang gt and I bought the car with 50 thousand miles and I replaced oil with royal purple around 53 thousand. And now iv got about 59 thousand. I was thinking about changing oil and spark plugs what else should I do?
Luna1994 is offline   Reply With Quote
Old 04-13-2013, 11:54 PM   #2
Air filter
Fuel filter
Breaks
Trans fluid
Coolant
Andy714 is offline   Reply With Quote
Old 04-14-2013, 08:51 AM   #3
08Mustang's Avatar
Change before 6k miles, do it about every 5k...and get some platinum plugs, new coil packs, fuel filter, k&n air filter, clean your throttle body, and put some fuel system cleaner in your tank next time you fill up! That's a complete tune up pretty much
08Mustang is offline   Reply With Quote
Old 04-15-2013, 09:05 AM   #4
Send a message via AIM to Borii
Oil interval straight from Ford is 7500.
Royal purple can easily be run to 10k but I still do it at 5k since abuse her at the track
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 04-15-2013, 03:23 PM   #5
Luna1994's Avatar
Region: Utah
How hard is it to change tranny fluid
Old 04-16-2013, 07:16 AM   #6
Not at all. Drain like normal but filling is tricky because the filler hole is on the side. I bought a tub, stuffed it through the shifter area in the hole and filled it.
Sold - 2001 Audi S4
Old 04-16-2013, 01:38 PM   #7
Davo_281GT's Avatar
Originally Posted by Borii View Post
Not at all. Darin like normal but filling is tricky because the filler hole is on the side. I bought a tub, stuffed it through the shifter area in the hole and filled it.
How much fluid does it take to refill? What about a trans filter?
Davo_281GT is offline   Reply With Quote
Old 04-16-2013, 03:09 PM   #8
Bout 9 qtz.. and yes it does have a filter
Old 04-17-2013, 07:34 AM   #9
It is 3.2 in a manual and manuals do not have filters.
Unless he has an auto, which is also not 9 quarts, it is approximately 11.9 quarts.
Without a full flush you get 9 quarts, that is incomplete.
08 GT may change a bit as far as oil requirements.
Sold - 2001 Audi S4
Old 04-17-2013, 09:11 AM   #10
Send a message via AIM to Destination S19
Don't forget the cabin air filter. No one seems to suggest changing them but it keeps life in your A/C blower motor and smells out of the cabin.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 04-17-2013, 10:01 AM   #11
Yes!! Smells!! lol They can smell like dead people.
Sold - 2001 Audi S4
Old 04-17-2013, 10:11 AM   #12
Davo_281GT's Avatar
Or dead mice, like we found in the ducts of my wifes new sonata. Awful!
_____________________________________________________________
Also, I have an Auto. But I'm hoping that will change soon when the new GT comes out. I've only ever owned manuals, and i'm starting to miss clutching. lol.
Old 04-17-2013, 10:32 AM   #13
When I removed my manifold for cmdps install, there were hundreds of nuts in the space below it and a dead squirrel. Looked like it cooked.
Sold - 2001 Audi S4
Old 04-17-2013, 12:55 PM   #14
garbill2003's Avatar
Don't over look your rearend and a tire rotation also do not change them cop's unless your upgrading or they are going bad.
garbill2003 is offline   Reply With Quote
Old 04-17-2013, 01:17 PM   #15
Rotation is great until you have staggered
Sold - 2001 Audi S4
Old 04-17-2013, 01:19 PM   #16
Yeah tell me about it Iam screwed their. I take it yours are also staggered?
Old 04-17-2013, 01:31 PM   #17
Yes, Nitto 555 255/18 up front and 305/18 555R2 up front. Not even the same tire lol
Sold - 2001 Audi S4
Old 04-17-2013, 01:41 PM   #18
Rosco's Avatar
Coil packs??? Why waste all the money on those when they function properly?
1998 Bright Atlantic Cobra - 3:73's, BBK ls, Pro 5.0, 96 Cobra STB, Borla XR-1 Catback, Custom Catch Can, Spec clutch, MM Firewall adj, FRPP wires, RSD, Spoiler delete, 245/275 BF Goodrich g sports on chrome 95 cobra r's
1998 V6 Mustang : SOLD!
Rosco is offline   Reply With Quote
Old 04-17-2013, 01:42 PM   #19
08Mustang's Avatar
Just might as well upgrade em
Old 04-17-2013, 01:48 PM   #20
There isn't really any "upgrade" to be had with new coil packs except new coil packs. They are one of those things you buy when something is a miss.
Cars with 0 miles would most likely pull the same power and times as car with old coil packs after 50k, baring any sustained damage and assuming proper maintenance.
Sold - 2001 Audi S4
Old 04-17-2013, 02:01 PM   #21
08Mustang's Avatar
I'd definitely have to disagree! You will lose power in the coil packs as they age along with wires and spark plugs.
Old 04-17-2013, 02:45 PM   #22
I find myself agreeing with Borii a lot today haha! The factory COPs are the best you can get for the most part. If you feel like they need to be "upgraded", just buy new factory replacements. I haven't heard anything good about Accel or Granatelli, the only other option being MSD, and for the costs and lack of proven benefits, stick with stock COPs. Even people making 800hp are running factory coils.
Old 04-18-2013, 06:33 AM   #23
Can you substantiate this?
Sold - 2001 Audi S4
Old 04-18-2013, 08:51 AM   #24
Rosco's Avatar
Well stated.
Old 04-18-2013, 01:53 PM   #25
Davo_281GT's Avatar
Nothing like some good ole' squirrel jerky, lmao!!
Old 06-18-2013, 12:03 PM   #26
dmarq's Avatar
I had a question about the fuel filter...service center told me this needs replaced every 15k miles...that seems ridiculously often. It's taken me until adulthood and the purchase of my first home until I was finally able to afford the mustang I have now, until then, I had mostly driven Honda's and they NEVER required a fuel filter replacement in any services I had done...why does Ford say every 15k for this car? I understand a 4 banger gorcery getter requires less fuel than my v8, but still, from never to every 15k? Is it truly needed that often or can I stretch it out...car currently has 31,000 miles on it.
dmarq is offline   Reply With Quote
Old 06-18-2013, 01:11 PM   #27
610swolf's Avatar
i would assume that it is, fuel filters get dirty like any other filter and robs you of power. Besides a oem replacement filter is 15 bucks and it's literally a three minute job to get the old one out and the new one in. I don't even jack up the car. I changed mine about 5 months after I got the car thinking that the dealership had taken care of most of the maintenance things... and mine was disguisting. I could tell that mine had never been changed.
610swolf is offline   Reply With Quote
Old 06-18-2013, 11:15 PM   #28
Do you just take off the old one like that? No need to close the fuel lines? Also where is it located
Old 06-19-2013, 04:58 AM   #29
610swolf's Avatar
Yep it's super simple. The fuel filter is located on the drivers side right under the driver seat. If your looking at this area you'll see a a black cover. Remove the 10mm screws holding the door and when it drops you'll see the fuel filter. Theres also a push pin you need to push in to get the door to come down. From there all you do is remove the bolt securing the fuel filter, push in the two latches and pull to get the fuel filter out and install the new one. Before you start though relieve the fuel pressure and make sure your fuel pump isn't on otherwise you'll have a huge mess to clean up haha.
Old 06-19-2013, 08:57 AM   #30
BaSohol's Avatar
I would change it every 25,000 miles and if that's too much money for you, for sale signs are at Walmart for 98¢
I changed mine at 55,000 and whoa was it dirty and I run BP or shell 93
2007 Ford Mustang GT 5spd
Old 06-19-2013, 09:41 AM   #31
dmarq's Avatar
If this post was directed to me, the cost of the service is not what I was asking about and I can do without the sarcasm...I can more than afford the car...but thank you for answering my question. I will change it soon and every 20-25k going forward.
Old 06-19-2013, 08:46 PM   #32
Terminator's Avatar
Hahaha
Terminator is offline   Reply With Quote
Old 06-19-2013, 08:49 PM   #33
2300turboford's Avatar
He wasn't being a smart a$$ he was just kidding around
Old 06-19-2013, 10:39 PM   #34
BaSohol's Avatar
Lol c'mon lighting up
Old 06-19-2013, 11:09 PM   #35
Thanks man.. lol how do u know if your fuel pump is on.?
01:01 PM
