Oil on throttle body. - Mustang Evolution
Old 04-15-2013, 12:53 PM   #1
eouellette18's Avatar
I took off my throttle body today and when I looked at it, the side that attaches to the intake manifold had oil on it. Mainly on the butterfly valves. What does this mean?!
eouellette18 is offline   Reply With Quote
Old 04-15-2013, 01:05 PM   #2
Aggiesrok's Avatar
You need an oil can catcher. The pcv tube begins sucking oil mist from the valve train. You then burn it through the intake, the catch can allows the oil droplets to be trapped and not go into your intake. You empty it when you change your oil, AM has some for a little over $100. It's a 90 second install.
Old 04-15-2013, 07:38 PM   #3
Does the catch can help on stick car? Or just get blow by with forced induction. Thanks.
Adam302gt is offline   Reply With Quote
Old 04-15-2013, 08:13 PM   #4
Terminator's Avatar
I wish it only took me 90 secs mine took like 30 mins
Terminator is offline   Reply With Quote
Old 04-15-2013, 08:48 PM   #5
DaBluedude's Avatar
Depends on lots of stuff. But lots of na cars benefit from a catch can.
2003 Mach 1
Old 04-15-2013, 09:49 PM   #6
Aggiesrok's Avatar
I put it on my 5 sp. I'm NA and still get oil in it. It's a great fix.
Old 04-16-2013, 12:16 PM   #7
Thanks, meant to type "stock", not "stick" car, but looks like you knew what I meant. So just driver's side or both?
Old 04-16-2013, 01:02 PM   #8
Aggiesrok's Avatar
You just need one, it goes on the drivers side, mine is the JLT black can, AM has them. It has the hose already attached, you just unhook the old hose and the can and hose replaces the entire piece. The JLT has the oem connectors on it.
Old 04-16-2013, 01:25 PM   #9
jdavis96gt's Avatar
Region: West Virgina
I thought passenger side was pressurized so fist catch can should go on passenger? ??
Old 04-16-2013, 01:34 PM   #10
Aggiesrok's Avatar
Not sure about that, but this installs on the pcv side (drivers side). AM has plenty of pics, I don't have one of mine in my phone.
Old 04-16-2013, 01:52 PM   #11
jdavis96gt's Avatar
Maybe its the 2v, I'm thinking about.
12:18 AM
