Eibach Coil over kit HELP!!!!!!! - Mustang Evolution
Old 04-22-2013, 05:23 PM   #1
Im trying to get a coilover kit for my 2007 mustang gt/cs and its procharged so it has a little added weight on the front. And ive been looking at the eibach 35101.711 kit which is the correct one for my car which will also fit a 2007 gt500. Eibach also sells 35115.711 which is specifically made for 07-10 gt500. as far as my search the only difference i can find is that they are rated differently the gt is 315lb/in and the gt500 is 400lb/in on the front. Could i buy 35115.711 and install it in my regular gt. since i can also get a better deal on it?
aaggy is offline   Reply With Quote
Old 04-22-2013, 05:38 PM   #2
bobsurvives's Avatar
The best thing to do is contact Eibach directly and tell them everything your car has
bobsurvives is offline   Reply With Quote
Old 04-22-2013, 05:52 PM   #3
They weren't much help and said if i were to install the other part on my car that they wouldn't cover the warranty on the coilovers. Im not trying to bash on women but a women helped me when i called and all she said was on eibach kit was for a gt500 and the other was for a regular gt. i tried asking for specifications on them but she said she didnt know.
Old 04-23-2013, 01:09 AM   #4
Venomouz831's Avatar
Well the gt500 is also heavier for having a bigger engine. 5.4 compared to a 4.6. I would just go with what is made for you're car
)02 Gt, Founder of WE2G
Old 04-23-2013, 06:05 AM   #5
the 5.4 is only about 75lbs heavier than the 4.6, since the 5.4 is aluminum and the 4.6 is iron block
Old 04-23-2013, 06:41 AM   #6
Alonzo.dargan1's Avatar
The 4.6 is aluminum as well.
Alonzo.dargan1 is offline   Reply With Quote
Old 04-23-2013, 07:07 AM   #7
yes sorry i was thinking of my 2004 gt with the Iron block.
Old 04-23-2013, 07:30 AM   #8
IMO I you well be good with the kit for the gt.... There are many mustangs with power adders(extra front weight). Some still use the stock suspension on their and others don't. In other words your would have no problems with the eibach kit.
Old 04-23-2013, 09:30 AM   #9
Thanks. so i guess my next question is when would it be a good idea to go with a higher rated spring or not at all. what are the benifits and cons?
Old 04-23-2013, 10:32 AM   #10
What kind of springs do you have in mind?
---------- Post added at 12:32 PM ---------- Previous post was at 12:28 PM ----------
What springs do you have in mind?
Old 04-23-2013, 11:17 AM   #11
prokit or sportline? eiback
Old 04-23-2013, 01:24 PM   #12
Go with the prokit
Old 05-05-2013, 07:02 PM   #13
Mark221's Avatar
The 5.4 is iron too
Mark221 is offline   Reply With Quote
10:07 PM
