just ordered these suspension parts did i forget anything? - Mustang Evolution
Old 04-28-2013, 09:12 AM   #1
Kochieey's Avatar
just ordered several suspension parts for my 07 mustang gt....Eibach pro system plus:front struts,rear shocks,pro kit lowering springs,35mm tubular front sway bar with bushings 3 way adjustable,22mm solid rear sway bar with bushings,steeda bumpster kit,j&m camber plates,j&m adjustable rear upper control arm,j&m rear lower control arms,ford racing front lower control arms with ball joints,j&m adjustable panhard rod.......just wondering if there was anything else I forgot for a successful lowering of my mustang ???? THANKS!!!!
Kochieey is offline   Reply With Quote
Old 04-28-2013, 02:28 PM   #2
Dang, quite the purchase! With that list you should be well on your way. Going to install it all yourself?
Adam302gt is offline   Reply With Quote
Old 04-28-2013, 04:04 PM   #3
610swolf's Avatar
that's just for lowering the car? I'd say your pretty set haha
610swolf is offline   Reply With Quote
Old 04-29-2013, 10:22 AM   #4
Kochieey's Avatar
Got my tax return I figured I would do the job right and get all the parts now just making sure I had all the right parts....and no I'm not going to do the installation myself which is going to kill me
Old 04-29-2013, 12:42 PM   #5
Send a message via AIM to Destination S19
I highlighted the list of things you need in red, and blue that you don't if this is only for lowering a daily driver and you don't plan on corner carving.
I also owned the J&M adjustable panhard bar, but I went with the aluminum one, do yourself a favor and skip that one and go for the steel bar. The aluminum one flexes under suspension compression.
You don't really need the bumpsteer kit but some people like to have it. The sway bars aren't needed either and I usually suggest those only after doing springs/shocks, that way you can decide if you really need to further correct any suspension problems like under or oversteer. If this is a daily driver and not a corner carver, the factory bars are fine. Also, the upper control arm isn't required unless you're using a one piece drive shaft, and there are ways around that.
Just a little helpful info if you're only interested in getting it lowered and getting some items like camber and rear end centerness back on track.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 04-29-2013, 01:01 PM   #6
Kochieey's Avatar
Thank you
Old 04-29-2013, 01:22 PM   #7
garbill2003's Avatar
She going to stick to the road
garbill2003 is offline   Reply With Quote
Old 04-30-2013, 04:44 AM   #8
GTRob504's Avatar
Don't forget lca relocation brackets to improve the lca angle to prevent wheel hop and improve hard straight launches
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 04-30-2013, 03:18 PM   #9
Kochieey's Avatar
another question so I ordered those parts and the eibach pro system did not come yet but all other parts did....I recently got my car inspected and was told I need ball joints...so I went and ordered new ford racing front lower control arms with ball joints.... My question is since I have the front control arms and bumpster kit before my lowering spring kit can I have have the front control arms and bumpsteer kit installed before having the car lowered????
Old 04-30-2013, 10:38 PM   #10
How long is the wait? I personally would do it all together and get it aligned together.
Old 05-01-2013, 12:34 AM   #11
Silver06GT's Avatar
+1 You'd be paying for someone to align it twice and rip up the front end twice, which ends up being more time spent at the shop too.
Silver06GT is offline   Reply With Quote
Old 05-01-2013, 07:28 AM   #12
Kochieey's Avatar
the wait is 2-4 weeks for the eibach kit bc American muscle said they do drop shipping and eibach custom orders....I also have a lifetime wheel alignment I just got last week....should I wait a few weeks still ??
Old 05-01-2013, 10:53 AM   #13
Aggiesrok's Avatar
You're still doubling the labor on the front end work almost. Also make sure that the lifetime alignments don't have an exception for your "performance parts" changes.
There is a brake shop here that sells lifetime brakes, but it's pads and or shoes, but when you take it in, they find bad caliper seals or bad wheel cylinders or overcharge for turning rotors or for additional fluid, etc.
Old 05-01-2013, 02:39 PM   #14
Kochieey's Avatar
Okay thanks got to look into that
« Mgw | Opinions »
02:23 AM
