Oil tap outlet 4.6 first start up - Mustang Evolution
Old 05-05-2013, 12:45 PM   #1
Bennyhill's Avatar
Does anyone know where to tap in and inject oil, on the first start up of a 3v 4.6l engine. I understand it's important to pre lube a modular engine before start up. Where does one tap into the valve train without actually tapping into the block?
Bennyhill is offline   Reply With Quote
Old 05-10-2013, 12:45 PM   #2
Bennyhill's Avatar
Don't worry I found it. For future references to this forum, in order to pre lube before start up on the 4.6 3v engine. Oil is injected by the oil filter at the oil outlet port. You will have to remove a sensor and inject oil through that port..
Old 06-02-2013, 07:26 AM   #3
Don't understand the issue. Injecting when for what reason? After oil change drain? Never heard of it in my 76 years.
CRASHG63 is offline   Reply With Quote
Old 06-02-2013, 11:28 AM   #4
SSTHIS's Avatar
On first start up of a freshly built motor you prime the oil system. On the old 5.0 you would remove the distributor and insert a tool attached to a drill and spin it to prime the system. Helps to prevent galling the bearings when cranked up. Some people just use engine lube when assembling the motor and go with that but if it has sat for years without startup then it's usually a good idea IMHO
SSTHIS is offline   Reply With Quote
Old 06-02-2013, 11:34 AM   #5
99mustang99's Avatar
Had to do to my brother chevy 350 bottom end rebuild just protects the parts you invested in
99mustang99 is offline   Reply With Quote
05:54 PM
