chatter sounds - Mustang Evolution
Old 05-09-2013, 08:26 AM   #1
S197Miller's Avatar
chatter sounds
I have a 2007 gt 5 speed. Whenever I'm around 3500rpms and up, and I floor it I'm getting a rattle chattering sound that seems to either be coming from in the cockpit or through the transmission hole. It just started today. I know its not interior rattle because it sounds different and I know what pieces of my interior rattle. And ideas or had anyone heard of something coming lose and can be heard through the transmission hole?
S197Miller is offline   Reply With Quote
Old 05-09-2013, 08:39 AM   #2
DaBluedude's Avatar
Possible shifter bushing. But more likely something in the rear end. Hard to guess from the description.
2003 Mach 1
Old 05-09-2013, 08:42 AM   #3
S197Miller's Avatar
Its hard to describe. It's not extremely noticeable like some sounds on the car. But it bothers me because it just started.
Old 05-09-2013, 10:21 AM   #4
Aggiesrok's Avatar
Pop the boot off the shifter and pull it up some and see if it's worse. Also is it in all gears at 3,500 and floor it? How many miles? What mods, if any?
289 - Holley 4150 570cfm; Performer intake; mild cam; MSD HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 05-09-2013, 11:10 AM   #5
S197Miller's Avatar
Mostly in third and fourth. 35, 000 miles and full exhaust with cai and tune.
Old 05-09-2013, 12:24 PM   #6
S197Miller's Avatar
Took the shifter boot off and could barely hear it. Exhaust was too loud coming through kind of masked over the sound. Put the boot back on and it does it from second through fourth. But only when I floor it. I can ease up to 4500rpms with no noise but once I floor it the sounds starts up. Its not a constant rattle, just happens a few times through out the acceleration. One thing I noticed was a thick black tar and grit on the shifter pivot. Its a Hurst shifter so maybe its going out?
Old 05-09-2013, 01:21 PM   #7
Aggiesrok's Avatar
Maybe the shifter is loose. That forward bolt is hard to tighten or the rubber isolator around the shaft underneath is damaged. You might get underneath and check it out. It should not be going bad this soon.
Old 05-09-2013, 04:19 PM   #8
S197Miller's Avatar
I've had the shifter for more than a year. Could it just randomly come loose?
Old 05-09-2013, 06:50 PM   #9
Aggiesrok's Avatar
It shouldn't. Only of it was not tight to begin with.
Old 05-10-2013, 05:41 AM   #10
Filf's Avatar
Did you fill up recently? I had that noise when I romped on the throttle as well but only when I used 91 octane. If I use 93 I don't get that chatter noise.
Filf is offline   Reply With Quote
Old 05-10-2013, 12:35 PM   #11
Sully08GT's Avatar
Region: Delaware
I had the same thing going on with me... Just installed a Bama 91 oct performance tune after I filled up with 91 and heard a similar noise went I floored it in 2nd and 3rd at higher RPM's. went back to my 87 street tune and it was fine. Now I started using 93 oct for the 91 tune and it seems to be gone.
Current Mods: Bama 93 Race Tune, Borla Stingers Axle-Back, Prochamber O/R mid pipe, JLT Series 3 CAI, Koni STR.T Shocks and Struts & Steeda Ultralites
Sully08GT is offline   Reply With Quote
Old 05-10-2013, 02:41 PM   #12
S197Miller's Avatar
Well I noticed it without flooring it. I think something went loose or my exhaust is hitting something. I might have hit it and bent it up and now i could hitting the frame?
11:02 AM
