Brake Noise - Mustang Evolution
Old 05-09-2013, 02:08 PM   #1
Brake Noise
I have an 08 Mustang GT Conv in which I just replaced the brakes and rotors. The brakes are a kevlar, semi-metalic and the rotors are cross drilled and slotted. After 2 weeks, I am getting a scraping noise similar to that of low brake pad indicator.
terryj074 is offline   Reply With Quote
Old 05-09-2013, 03:28 PM   #2
1slosix's Avatar
is it all the time or just when you brake?
carving corners like a boss
Old 05-09-2013, 06:49 PM   #3
fastmustangs1's Avatar
could just be the pads ur running.
fastmustangs1 is offline   Reply With Quote
Old 05-09-2013, 07:15 PM   #4
BaSohol's Avatar
Did u clean your slides? Or half *** it and skip that step
2007 Ford Mustang GT 5spd
Old 05-09-2013, 08:01 PM   #5
It happens when I brake lightly, when I brake to stop, no noise. I've used the pads on other stangs and no noise. Nothing half-assed with what I did, Cleaned the slides and used a light coating of white lithium grease
Old 05-09-2013, 10:01 PM   #6
BaSohol's Avatar
That lithium grease probably burned off by now
Old 05-10-2013, 05:37 AM   #7
Filf's Avatar
Need to use brake grease. Also did you remember to reuse the shims?
Filf is offline   Reply With Quote
10:28 PM
