Rattle after lowering kit - Mustang Evolution
Old 05-12-2013, 03:37 PM   #1
JonChambers03's Avatar
I lowered my 09 GT, and it now has a rattle in the right rear. I crawled under it and had someone bounce it, found the rattle is the adjustable pan hard bar I installed. Is there a way to make it stop rattling or another pan-hard that doesn't rattle?
JonChambers03 is offline   Reply With Quote
Old 05-12-2013, 10:44 PM   #2
Silver06GT's Avatar
I had the same issue. Pan hard adjustment nuts were not tight. Put some loc-tite on the threads of the adjusment screw and retighten the nuts. What bar are you using?
Silver06GT is offline   Reply With Quote
Old 05-12-2013, 11:02 PM   #3
Abominable Mustang
WhoDat's Avatar
Region: Alaska
+1
I had one of my adjustable panhard bar's jam nuts loosen and it started rattling. A lil loctite and retightening. No issues since.
2012 Kona Blue 3.7L V6:
Old 05-13-2013, 07:16 PM   #4
I tried retightening and using loc-tite, didn't help at all. As soon as I backed down the drive way it was rattling the same. It seems to me it may be coming from where it bolts up on the right side.
Old 05-13-2013, 09:05 PM   #5
Silver06GT's Avatar
Is the panhard bar support brace tight on the passengers side? I would just go over all the nuts & bolts to make sure they're tight. Eliminate all other possiblities before you send it back. What bar are you using?
Old 05-14-2013, 05:31 AM   #6
I've actually had it for a while now, so I'm not sure which brand. I know it's an on car adjustable. Both nuts are tight and the bolts on each end are tight. I know when someone pushes down on the right fender making the car jounce, I can hold the pan hard bar and it immediately stops the rattle.
Old 05-14-2013, 05:48 AM   #7
I was just checking out some other ones. I think I like the ones like the BMR one. The adjuster looks a lot easier to access and it has bushings. I'm pretty sure that'd be much more quiet.
Old 05-14-2013, 07:27 AM   #8
Aggiesrok's Avatar
Is it a bar or a piece of channel? It could be cracked where you can't see. Sounds like a new one in your future.
Old 05-14-2013, 10:14 AM   #9
sinister07's Avatar
I had an adjustable bar in my black car that had Heim joints at each end. It did not rattle, but it did transmit every little sound into the car.
2003 Mach 1
sinister07 is offline   Reply With Quote
Old 05-14-2013, 11:18 PM   #10
Silver06GT's Avatar
That's very true, forgot about the Heim joints.
Old 06-01-2013, 07:58 AM   #11
I ended up ordering a BMR pan hard with polyurethane bushings. My previous one had Hiem joints and that was exactly what was rattling.
12:13 AM
