Hand brake help!!! - Mustang Evolution
Old 06-26-2013, 04:54 PM   #1
silverstang831's Avatar
Hand brake help!!!
When I put my hand brake I heard a weird noise now my hand brake has no tension. I checked my back brakes and notice this? How can I put the cable end in the lever?
silverstang831 is offline   Reply With Quote
Old 06-26-2013, 07:04 PM   #2
vise grips or pliers and yank back out and hook it in, assuming the cable isnt froze up? never seen one just pop off..
Boss IM, with Araid cai, bama 93 race tune, GT500 cat back, jba off-road x-pipe & longtubes, mgw shifter,4.10 gears, Aluminum Flywheel & driveshaft, Adjustable Panhard Rod, BMR adj. uca & lca, BMR relo. brackets, BMR Springs with 1.5" drop, BMR adj. swaybar, BMR tubular K member 1/2 drop motor mounts & BMR tubular A arms, steeda alu. rad. support, aluminum water pump pully, 85mm BBK TB, Rear seat delete. Boss oil cooler, Battery in trunk. AC delete, Evap delete
brianw64 is offline   Reply With Quote
Old 06-27-2013, 12:40 PM   #3
Its impossible so I'm assuming it froze up? I tried the other side and I can take off the cable end and put it back in the lever easy as 123 ha
05:02 AM
