I have a misfire.. - Mustang Evolution
Old 07-02-2013, 11:28 PM   #1
Graham1992's Avatar
I have a misfire..
So I've been having alot of trouble here lately about a "misfire" on cylinder 5. It misses frequently and violently while idling but will stop at 2 grand.. Like completely stop and won't miss again. Wth? I put new plugs and it stopped for a week then started missing again. I tried a new coil pack on cylinder 5 and that didnt help so it's not that. I've resorted to thinking that the injector is stuck open but it leans out at 2 grand.. Injector cleaner doesn't help. Any suggestions? Tomorrow I'm taking the injectors out and sending them off to get new filters and seals.
Graham1992 is offline   Reply With Quote
Old 07-03-2013, 01:15 AM   #2
Alonzo.dargan1's Avatar
Have you ever put fuel additives in your before the misfires occured?
Alonzo.dargan1 is offline   Reply With Quote
Old 07-03-2013, 01:24 AM   #3
Stang.racr's Avatar
Does it have. Tuner or throwing any codes?
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-03-2013, 02:58 AM   #4
Graham1992's Avatar
It through a misfire on 5 and I always run fuel treatment every few tanks and yes it has a Dyno tune
Old 07-03-2013, 06:56 AM   #5
You are fouling out your plugs with the fuel additives causing you to misfire... I had the same problem, tried everything. Then my friend told to stop with the fuel additives and replace my plugs and it fixed my problem. Hope this helps.
Old 07-03-2013, 03:14 PM   #6
Graham1992's Avatar
What do you mean fuel additives? Like injector cleaner and so on?
Old 07-03-2013, 04:05 PM   #7
Yea all those. What kind of plugs are you running?
Old 07-03-2013, 05:15 PM   #8
Graham1992's Avatar
Auto lite hto. One step colder heat range
Old 07-03-2013, 05:20 PM   #9
Yea i run the same plugs. That fixed my issue.
Old 07-03-2013, 05:21 PM   #10
Graham1992's Avatar
Just get another set? And stop running additives?
Old 07-03-2013, 05:31 PM   #11
Yea and it fixed my issue... hope it works for you
Old 07-03-2013, 06:24 PM   #12
Graham1992's Avatar
I hope it does too lol thanks alot man.
Old 07-03-2013, 06:28 PM   #13
No prob
Old 07-10-2013, 12:08 AM   #14
Did that work for you?
Old 07-11-2013, 02:35 PM   #15
Graham1992's Avatar
I haven't had the chance to put the plugs in. I just been driving around running the injector cleaner out. Should be looking at it more Monday or so. Do you think maybe the plugs are gapped? I had the injectors cleaned and they were fine.
Old 07-11-2013, 04:50 PM   #16
If you bought the autolites again they are pregapped to .35 but i always check to see if it was correct. If you already ran out all the old fuel, you can install your new plugs
Old 07-12-2013, 11:04 PM   #17
Graham1992's Avatar
So here's the deal.. It's not the injectors or the coils. So spark plug is all that's left unless its wiring or a whole in a vacuum hose. So your saying a new set of these plugs WILL PROBABLY do it?
Old 07-13-2013, 12:27 AM   #18
Yea a new set of plugs will fix your issue
Old 07-13-2013, 12:41 AM   #19
Graham1992's Avatar
I really really hope your right.. I'm gonna switch a few plugs around to see if it starts missing with just one or two plugs
Old 07-13-2013, 12:51 AM   #20
All the plugs that are in your car more than likely foul....i tried switch my plugs around and found out they were all fouled out....i bought a whole new set of 8 plugs and my issue of misfiring was gone
Old 07-13-2013, 11:42 AM   #21
Graham1992's Avatar
That was how long ago?
Old 07-13-2013, 03:14 PM   #22
6 months ago
Old 07-13-2013, 03:46 PM   #23
6 months ago
Old 07-13-2013, 04:25 PM   #24
Graham1992's Avatar
6 months ago
Okay just making sure. Mine is only missing to 2000 RPM... Sound about right still?
Old 07-13-2013, 04:38 PM   #25
Yea mine would misfire at 3500
Old 07-13-2013, 04:47 PM   #26
Graham1992's Avatar
Shew alright man lol thanks alot. Ill post again if I have any questions and when I get them installed.
Old 07-13-2013, 05:03 PM   #27
Ok man...it should fix your issue
Old 07-18-2013, 03:07 PM   #28
Graham1992's Avatar
Hell yeah! I switched the plugs around and it stayed with the plug. So I plugged it up to a code reader and it said my o2 sensor was "stuck open" so I changed the o2 and the plug and it's running perfect! Thanks man for all your help.
Old 07-18-2013, 06:34 PM   #29
Nice glad you were able to fix it.
Old 07-19-2013, 10:28 AM   #30
have you tried tuning it?
ErikMustang is offline   Reply With Quote
Old 07-19-2013, 11:47 AM   #31
Graham1992's Avatar
It's all done lol I fixed it
Old 07-19-2013, 08:37 PM   #32
Maraqt101's Avatar
I had the same problem! Wish I had seen this earlier before spending so much time playing around with her
Maraqt101 is offline   Reply With Quote
09:05 PM
