Need basic help with rims - Mustang Evolution
Old 07-06-2013, 05:13 PM   #1
Hi, I have a 2009 GT Mustang. Putting new wheels and rims on. My wheels are 18" 8. I cannot find the Saleen rims (or equivalent) with an 8 offset. Can I use the 9's or 10's and what would that mean the looks of the car and performance? Thanks for your help.
midweststeeler is offline   Reply With Quote
Old 07-06-2013, 05:27 PM   #2
S281's Avatar
Not sure what you mean by 8 offset, are you talking about 8" width?
S281 is offline   Reply With Quote
Old 07-06-2013, 06:06 PM   #3
stemar's Avatar
I have the Factory 18" fan blades on my car they are 18x8.5" wide not 8 they have a 50mm offset I beleave the factory 18" Bullets are the same .
Most aftermarket 9" wheels run a 30mm backspace or offset this means they will put the wheel and tire out close to the fender lip for a meaner look.
I installed 1" or 25mm wheel spacers on my car with the factory wheel witch would be the same as if my stock wheels only had 25mm offset instead of 50mm
Pypes shorties, BBK catted X, Flowmaster Pro's, K&N CAI, FRPP- P springs, Steeda UCA, J&M Panhard bar, Hurst Comp plus, FR500 Wheels W/NITTO's , SCT SF3 W/BAMA 93 Race tune, Pioneer TS-D6802R speakers, chin spoiler, Eleanor style grill, GT500 rear spoiler
stemar is offline   Reply With Quote
Old 07-06-2013, 09:58 PM   #4
C_Dailey95's Avatar
Stock offset is 45mm isn't it?
C_Dailey95 is offline   Reply With Quote
Old 07-07-2013, 05:19 PM   #5
Sorry, yes I meant the width is 8. I found Saleen's at 9. Can I use them or will this cause a problem?
---------- Post added at 05:14 PM ---------- Previous post was at 05:13 PM ----------
Yes, I misstated the question. I want to know if I can use 9" width instead of 8's?
---------- Post added at 05:19 PM ---------- Previous post was at 05:14 PM ----------
Just so I am clear, I can use 9's instead of 8's and won't have a problem? The guy at the tire store seemed a little unsure, but he told me I could not use 9's. My problem is the Saleen rims I want are only in 18/9. Thanks in advance.
Old 07-07-2013, 05:31 PM   #6
S281's Avatar
Do you know the offsets?
Old 07-07-2013, 06:32 PM   #7
C_Dailey95's Avatar
You should be fine. As log as the offset isn't to low you'll be fine with the 9".
02:34 PM
